Hello all,
Been out of the overclocking game for a while and finally got a new setup. Have the following components:
i5 750
gigabyte p55a-ud3
4gb dd3
750 gb seagate
ocz 600w modxstream
So far, the highest stable OC i've gotten with stock volts is 3.3 + turbo. I just finished a 24hr session of prime95 @ 3.7 ghz + turbo (~3.9) @ 1.21 volts. Thinking that the best overall overclock for performance and efficiency is 3.6 ghz + turbo (~3.8) @ 1.68v. Have a couple questions though:
1. The computer seems to OC well but you really need to start pumping voltage in. I can do 4.0 without turbo but needs 1.31 volts. It seems like 3.6 ghz is the sweet spot since I only have to do a couple notches about stock volts and 3.7 plus turbo needs 1.225 in the bios for stability.
2. Is 24 hours of prime testing enough for general system stability? Haven't really used any other programs but OCCT. Any suggestions?
3. Do people normally keep turbo on? I'm a little confused about it and have heard that when only 2 cores are stressed, the multiplier jumps to 24x? Is that true? I know when I am stability testing, the multi is at 21x since all 4 cores are stressed.
4. I have all the energy saving features on but have yet to see the voltage decrease. The multiplier will jump down to 9 but isn't the voltage supposed to drop as well?
Thanks for any help and sorry about all the questions!
i5 750
gigabyte p55a-ud3
4gb dd3
750 gb seagate
ocz 600w modxstream
