News Intel GPUs - waiting for B770
Page 20 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
mikk
4,291
2,381
Yep, wccftech interprets this now as DG1 is tigerlake's iGPU in a discrete form factor, with 96EUs.
It's more or less known for quite some time that DG1 is basically TGL GT2. A lot of people may have missed that DG1 is Gen12LP based and DG2 Gen12HP. DG1 never was going into the mainstream or higher because it uses the Gen12LP architecture. They still could reach 2 Tflop with 1.5 Ghz GPU clock which is comparable to an GTX 1050 Ti/GTX 1050 when it comes to raw power. I do hope Intel releases DG1 for the desktop and not only for mobile, I'm curious about the Quicksync and media capabilities of Gen12LP.
Bouowmx
1,150
553
DG1: Gen 12 LP, 96 EU/768 cores
DG2: Gen 12 HP, 512 EU/4096 cores
Did I get that right?
lobz
2,057
2,856
I meant wccftech presents it as the 96EU version would be the only one. That'd be an even weaker product than the 128EU one that everyone was talking about in this thread and the ICL/TGL thread.
jpiniero
16,493
6,988
wccf is wrong. It is 128, the 96 is a cut down model.
DG2 is presumably cancelled due to bad 10 nm yield.
Reactions: Tlh97 and lobz
jpiniero
16,493
6,988
That sucks, because the DG2 probably would be the one worth buying instead of a higher end Nvidia or AMD card.
I don't think Intel is going to give up completely, but I don't think you will see anything competitive with a higher end card until 7 nm at the earliest. I think the original intent was to do so, they just can't do it.
NTMBK
10,411
5,677
Assuming they get their 7nm process working a lot faster than they did their 10nm...
mikk
4,291
2,381
This is entirely fictitious, there is zero rumor that DG2 is cancelled, it's made up out of thin air from you as usual. You are really dubious lately.
jpiniero
16,493
6,988
Let me put it this way, there's even chatter now that DG1 is so uncompetitive that the design wins Intel got were only OEMs being nice. Not ready to go there just yet, but it's obvious they would be unable to yield something of the size of DG2 on 10 nm.
Reactions: Tlh97 and CHADBOGA
moonbogg
10,731
3,440
Its going to be a cheap IGP replacment/upgrade with an intel sticker on it. It's going to be a piece of crap.
mikk
4,291
2,381
You said DG2 is cancelled which is a different thing! It's more or less obvious that Intel won't release a DG2 next year and Intel never never confirmed it, they always just said first discrete graphics in 2020 which is a realistic target for DG1, if they can release Tigerlake 4+2 they should be able to release DG1. Further than that nothing is known about DG2 or Gen12HP in general. Basically you are saying DG2 is completely cancelled because there likely won't be a DG2 in 2020, really you are so dubious lately it's ridiculous.
IntelUser2000
8,686
3,787
It won't be the GPU to run your latest VR games on, but if they have very good perf/watt and perf/$ then it'll be a good product.
Low performance by itself isn't bad. Low performance combined with high cost and/or high power use is bad.
From the naming we'll see DG1 first. Maybe they'll release it in phases with DG1 LP coming in H2 2020 to displace 1650 in mobile, and DG2 HP coming in H1 2021 for the middle. High end they might want for the 7nm version some months after the HPC version releases, maybe towards early 2022.
lobz
2,057
2,856
If rumors are anything to go by, the last thing it will ever have is good power efficiency. Which also wouldn't be surprising, as it's seems to be the curse of Raja. Of couse I'm not talking about superstition, but somehow he always underestimates the power needs of the architectuers he's involved with.
Reactions: Tlh97
NTMBK
10,411
5,677
Low performance is a problem if it isn't noticeably faster than integrated graphics. At that point you're taking a big hit to battery life, chassis size and cost for very little benefit.
Reactions: Tlh97
Maxima1
3,549
761
Unless a graphics intensive program runs, discrete graphics doesn't kick in. I don't know why people always repeat this about battery life.
NTMBK
10,411
5,677
It's still sitting there drawing idle power for both the GPU and the VRAM. It's not like it's completely powered off.
Reactions: Tlh97
Maxima1
3,549
761
Nope.
lobz
2,057
2,856
There has been low power, lof performance mobile cards since time exists. I don't see what exactly this intel GPU supposed to offer.
Reactions: Tlh97
Maxima1
3,549
761
I never said it was good. I always thought the dgpus that barely performed better than the integrated parts were stupid solutions for taking the load off of some i7 SKUs. But maybe it isn't like that this time. There is a rumor Xe will have multi-GPU support....
jpiniero
16,493
6,988
Intel was intending to go after the high end (see DG2). But 10 nm happened.
DG1's target is 1050 Laptop/mx350, and not 1650 Laptop. Even getting that level of performance is unlikely.
lobz
2,057
2,856
If it really wants to target 1050 and mx350, then it's a hit and a big miss.
PingSpike
21,756
600
Is there any proof this actually worked though? I'm not saying that to be confrontational. I ran a bunch of experiments with their ZeroCore recently and I never got close to the 0 watt that claimed to use. I tried several supported cards. And aside from a single techpowerup measurement I can't find any proof it ever worked.
Maxima1
3,549
761
Well, I have a Haswell laptop with a discrete card, and it only shows it powering up if I do something graphic intensive, so I'm curious what you're doing to measure it. If I recall, Nvidia said AMD's solution didn't power down all the way (express bus still using 500 mW or something, which isn't that significant), but that was awhile ago, so I bet AMD's solution is really no better or worse than Optimus now.
PingSpike
21,756
600
I'm measuring at the wall with a kill-a-watt. Its certainly possible their laptop solutions work better than their desktop oriented one, I haven't tested those.
ZeroCore doesn't even work at all on Windows 10 and AMD has said it never will.
I'm certainly curious about the DG1s numbers and performance in this area.
IntelUser2000
8,686
3,787
I very well believe its going to need a bit more work on the higher end, but they are pretty good on the iGPU side. DG1 with 96EU is a dGPU version of the one in Tigerlake.
@NTMBK @jpiniero Not having to share memory and TDP will make it significantly faster. Unless they want to really gimp it by using 64-bit DDR4 or something and end up having significantly less bandwidth than TGL-U.
