Intel "Devils Canyon" Launch - Reviews, OC Info, Availability
BFG10K
22,709
3,003
The i7-4790K represents Intel’s first ever consumer processor with a base frequency of 4 GHz (we have CPUs that turbo this high), but the turbo mode for this processor is actually 4-4-3-2, meaning that at single core loads the user will see 4.4 GHz and at full-core loads it will be 4.2 GHz.
That's even better than I thought; I assumed it was 4-3-2-1.
So even if all four cores are loaded, you still get 4.2 GHz guaranteed at stock voltages, even on the crappy stock cooler.
Again, I can't see why people are complaining about this. :awe:
Techhog
2,834
The average overclock for this will be +100-300MHz, which is basically no performance increase. This would have been more impressive as a locked CPU.
Pheesh
138
Cool, you've already binned through ~30 processors yourself to determine a 100-300Mhz average overclock on a processor that isn't even shipping yet? Hook us up!
I'll still take the free performance boost for no additional cost.
kimmel
248
If I want baseless speculation posited as fact I'd watch TV news. :rolleyes:
blackened23
8,548
Indeed. 4.4ghz required 1.2V+ on the 4770k (for MOST 4770k CPUs) which is simply a no-go on the intel stock cooler. The fact that this chip can get 4.4ghz on the crap intel stock cooler at 1.1x V? It's a definite improvement. It definitely is better binned with improved power delivery. Some folks are complaining just because.
No, it isn't designed to be an upgrade for anyone with a 4770k. I can't believe that is being argued as the main perspective. But it WILL be a great upgrade for those coming from lynnfield, nehalem and SB CPUs.
TreVader
2,057
The point is with haswell-E and the hexacore for $400 there is zero reason to mess with the 4790K. When I saw the turbo I figured this would hit 4.6-4.8 on air pretty easily but it looks like its just a 4770K binned to the point of absurdity.
If you don't OC, this is certainly a great chip. Overclockers look elsewhere.
Bman123
3,221
How long do you guys think this new i7 will be a good gaming CPU? A good 3-4 years?
crashtech
10,695
2,293
It will be good at least as long and likely longer as any other Intel CPU in recent history, given the slowed pace of progress.
TuxDave
10,571
I game and my Core i5-750 is still pretty good after 5 years. I would say I upgraded my GPU once and I have an itch to upgrade it one more time before considering a new CPU.
I'm pretty sure the 4790K would last more than 3-4 years for me.
Aug 11, 2008
10,451
642
Well, to be fair, 4.4 stock is *not* on all 4 cores like it would be on an overclocked 4770K. So the comparison is not totally valid. A more accurate comparison of stock 4790K vs overclocked 4770k would be to use 4.2ghz as the 4970k clock on all 4 cores.
That said, I agree it is a nice improvement, especially since there was no price increase, and I agree some posters are just being overly negative, and are assuming overclocking will be no better than 4770k without sufficient data.
Personally, I think it will be somewhat better on average, since the 4790K is already basically overclocked to 4.2ghz with the stock cooler, and I doubt many 4770k would achieve that. Even if it were no better, so what, it was overhyped (like that is anything new for either intel or AMD), but you still get the same or better performance for the same price. Edit: and undeniably better stock performance.
crashtech
10,695
2,293
It's another small increment. Why is anyone surprised by this? At least there ARE performance increments. What have we seen from AMD? Low end stuff.
OCGuy
27,224
37
Microcenter (other than the one in OC darnit) is now showing them in stock and changed the release date to 6-3......people are getting notices to come pick them up....
Can anyone confirm??
AtenRa
14,003
3,362
I believe DC will get in to high voltage wall after 4.6-4.8Ghz and above with AIR and WC. So just because it can operate easily at 4.4Ghz doesn’t translate in to very high OCs. In fact LN2 ocerclocks didnt brake the 6.5GHz barrier (maybe they run in to coldbug ??).
blackened23
8,548
Huh??
Not 4.4 on all cores says who? This all depends on your BIOS settings. This is something you can configure, which an overclocker can and will do. Every asus motherboard i've owned has per core turbo settings. Multicore enhancement also does the same thing.
But if you're using a stock cooler at stock settings, yes, it's 4.2 on all cores. I don't imagine ANY overclocker will run the CPU like this. By the way, the turbo was the same way on EVERY OTHER K SKU. 3770k, 4770k, you name it. The turbo was the same way, didn't apply to all 4 cores at stock. But you just go in your BIOS and change that crap to turbo on all cores at your OC speed, easy enough. Practically every motherboard that I've used in the past couple of years and buddies have used do the same thing with turbo at stock. 4 core turbo is different at stock settings with a cheese stock cooler. But you just go in the BIOS and fix that up to turbo to full speed on all 4 cores. Or use Multicore enhancement..
rtsurfer
733
15
Depends.
I believe it is possible to dissipate upto 1.5V on Water if you have a high-end loop.
At those volts, the max frequency would be around 5Ghz or a bit higher.
AtenRa
14,003
3,362
Depends.
I wouldn't use 1.5V on FinFets unless you go sub zero.
rtsurfer
733
15
It is a bit risky but you can always get the Intel OverClockers warranty.
I ve seen some people run around 1.4V~ on water.
You can go chilled water or phase change if you want to do 1.5V everyday without risk.
Which would be sub zero as you said.
I ve heard about plenty of people running 1.5V+ on Sandy, don't know how much more delicate Haswell is.
It surely runs hotter.
Bman123
3,221
That's good enough for me. I'll only buy games during a steam sale most of my stuff is done on the new consoles anyways
Grooveriding
9,147
1,330
1.5V on Haswell is almost certainly going to degrade the chip very fast. Even 1.4V is going to kill it quickly imo. I've degraded followed by completely killing a SB-E with 1.4V over the course of about a year or so.
I don't think Haswell really can withstand much more than 1.3V for long-term use, even that might be too much. My 4670K gets really hot with just going over 1.2V in my experience.
StinkyPinky
6,973
1,276
This CPU is fantastic. FFS it's effectively 4.2GHz out of the box. That's a guaranteed healthy speed before you even try to overclock. I can't believe people are complaining about it simply because it can't do 5GHz+. Even in the enthusiast market the people that will push for that speed is minimal.
rtsurfer
733
15
I have my doubts.
But there are definitely people running 1.3V or more on Haswell 24/7.
Their CPUs are still alive.
Guess we won't know till somebody kills theirs.
I can run my 4770K @ 4.6Hhz with 1.315V & temps don't go over 65-70C for hours of gaming.
I have an H100i.
Techhog
2,834
I can vouch for that. By the way, it's really cool how Haswell increases voltage without you touching it if you overclock. :whiste:
