Yuriman
Isn't heat density just a symptom, the underlying problem being that electrical parameters are not keeping up with density increases?
I've seen it commonly speculated that 22 nm did not overclock as well as 32 nm because of heat density issues, but heat density has been increasing for quite some period of time now. I'm skeptical of the idea that it's only just now become significant roadblock. Certainly it is the nature of exponentially growing "bad transistor behaviors" to be a non-issue one node, and a severe headache the next, like gate oxide leakage at ~130 nm. However, you'd think that the credible authorities would have highlighted that heat density is, in fact, what's holding us back, rather than whimsically pointing out that we've got heat density on par with nuclear fission reactors, and doing nothing more than that.
My experience has been that I run into heat problems when I start to enter "dangerous" voltages (i.e. 1.3v+). Even with significantly lower temperatures, I doubt I'd want to run at that kind of voltage.
