Sureshot324
- Feb 4, 2003
- 3,370
- 0
- 71
It's $284 in quantities of 1000 so hopefully retail stores won't price gouge too much when it's released.
Originally posted by: Scoop
Am I the only one who noticed the TDP? 130W for all of them? What happened here? Penryn's consumption was looking so good and now they're throwing 130W chips at us AGAIN?
TDP does not equal CPU power consumption. The 130W TDP QX9650 in reality consumes about 65W, the 65W TDP C2Ds consume around 30W.
Nehalem will pull a few more watts than Penryn at the same clockspeed (due to the IMC being on die, and the cores being kept 'busier' with HT) but it won't be anything drastic: http://www.anandtech.com/showdoc.aspx?i=3326&p=8
In fact based on these results Nehalem has significantly better performance/watt.
Originally posted by: Anandtech
for a 20 - 50% increase in performance, total system power consumption only went up by 10%.
Originally posted by: Idontcare
Same can be said for the Phenom 9850 and 9950, in all cases you aren't missing a whole lot by not having the absolute top of the line these days.
Originally posted by: Cookie Monster
Think ill just wait for westmere.
Originally posted by: taltamir
And after the phneom 9950 you will get a new name, one not tainted by failure.
Originally posted by: nyker96
Is it me or does 130W sounds like enormous amount of heat here. If OCed I cannot imagine the final heat output from these babies at max load. Definitely need more case cooling for these guys. BTW, if the 920 can OC, that would be the hit chip.
Originally posted by: WaitingForNehalem
Why does power consumption matter? I doubt you'll notice a difference in your electric bill.
TDP = Thermal Dissipiate Power. It is a measure of the size of the HEATSINK recommended for that line of processors. It has very little to do with actual power consumption.
Originally posted by: aka1nas
IIRC, the TDP value is for the entire family, not individual CPU models
For the desktop enthusiast consumer:
Power consumption = heat generation = temperature = transistor signal/noise instability = lowered maximum operating clockspeed and lowered maximum operation lifetime.
Typically you want your processor to last a long time and operate at a high clockspeed.
Temperature will impact your CPU's lifetime and can (but not in every case) limit your CPU's peak stable clockspeed.
For the laptop consumer lower power dissipation means longer battery life or smaller battery and lighter laptop, and in either case a less warm lap.
For the corporate IT consumer it means reduced A/C bill for cooling that computer room (or building full of desktop PC's in everyone's cube) and lower electric bill to power the computer and lower initial costs to purchase the computers as the computer's cooling system and PSU can be rated for lower TDP and thus cheaper to purchase from DELL, etc.
It matters to just about everyone, they just might not realize it until they think it thru.
edit: To add some personal data, I run five (5) Q6600's 24x7 at 100% load and it adds $75/month to my electric bill.
Ahh, I see, the people here care about it for overclocking.
Originally posted by: Viditor
AMD has almost always followed the "entire family" model, but Intel has stuck with individual TDPs for each CPU (though this may have changed lately).
It has changed.
All C2Ds (or derivatives) currently on the market have a 65W TDP, which spans across 45nm and 65nm too. Obviously these CPUs don't all consume the same amount of power.
The same applies for quads, all C2Qs (except for EEs) are 95W, regardless if they are 65nm or 45nm.
Originally posted by: Byte
WOW $284 for an i7? That sounds really tempting.
Originally posted by: AmberClad
965? Why does Intel keep using that product code? Conjures up not so fond memories of obsolete chipsets and Pentium Ds.
