Awesome, like Shintai said, hopefully this gets FPGAs into more people's hands. I'm guessing taking some extra courses in FPGA design/theory wouldn't be a bad idea...
Not sure if this is the same idea that you were referring to, but there is a very interesting topic about self-programming hardware.
Mind you I literally just started research in this field (still reading through recent publications on the underlying principles of evolvable hardware, so my knowledge is INCREDIBLY basic on it).
My experience of these things is mighty expense, tricky programmability and most of the performance coming from fixed functions that can be called from the custom bits. I did an image compression algorithm on an FPGA a decade qo now and it worked well enough with a lot of source code tweaking but I have only ever considered it useful in very specialist cases.
