Intel’s Haswell to Feature Secrete Weapon: Integrated Voltage Regulator
Ajay
16,094
8,116
Secret-weapon, we've known about this for some time? Oh, parroting Xbitlab's sensationalist article :p
IntelUser2000
8,686
3,787
I can only see this as something that can potentially limit the ability to overvolt and overcurrent the procs if they so choose.
Shouldn't worry about this. They wouldn't provide overclockable K SKUs and mainboards with multitudes of overclocking options in the BIOS if they wanted to.
The fact is, even if significant amount of people overclocking resulted in less desktop sales, its an increasingly smaller market for them. They would do well to appease the enthusiast in that case, the only one where they said outside of the AIO and SFF market is a growing one for desktop.
Also, if each power cell really supports 25A, and there's twenty of them, its highly unlikely you'll be limited by that aspect either.
IntelUser2000
8,686
3,787
Made a false assumption based on Xbitlabs' misleading understanding of PCWatch's article.
The specific device that handles 25A and 16 phases per cell is a research chip. No known details for Haswell's FiVR exist.
I think what "Fully Integrated" refers is that the single die is capable of handling multiple voltage rails.
As for the version shown in Xbitlabs: They say that only 3 cells active are needed to fully power a 90W Xeon without problems. 20 cells indicate 500A, and if they integrate a derivative of that, there's no way you'd run out of power headroom because of the current "limitations". Also, having much higher phases would allow stability, potentially increasing overclocking potential.
320 phases is 20x what high end motherboards have.
Fixed typo.
StrangerGuy
8,443
124
So no mobo manufacturer has no chance to skimp on the VRM or hype their over 9000 phases digital VRM marketing hot air? I approve.
Haserath
793
More phases on a mobo generally used more power for no noticeable gain. I'd be glad if Intel controlled efficiency on that.
They'll most likely make everything better. It will be more difficult for the industry but better for us.
Homeles
2,580
We didn't know we'd be getting a high quality chip like this.
Edit: well, I guess that's still up in the air.
cbn
12,968
221
Intel17 said:
The enthusiast space, much like the All-In-One PC space, is one of the few desktop spaces that's actually growing quite nicely.
Intel cares very much about the enthusiasts.
I wonder what the motherboard people have to say about the possibility of the mainstream enthusiast and SFF converging....even more so than it has with Mini-ITX.
Could these integrated VRMs allow true desktop TDPs from something like NUC? (assuming the appropriate blower fan and heatsink is installed)
See picture below of current NUC cooling system on the back of the mainboard:
Picture of NUC with recess in the bottom of the enclosure for the above cooling system :
cbn
12,968
221
EDIT:
Some pics comparing NUC to a desktop cooler:
Based on that I would say it will be a challenge to get TDP up to desktop levels in such a small 4" x 4" package. However, I don't think it would be impossible if the height of NUC could be increased a little bit.
