No, because FC-pga chip construction is different than ppga chip construction. On PPGA chips, the CPu is on the "backside" section of the PCB. On Flip-Chips, it is on the oppposite side, above the PCB.
Isn't the integrated heat spreader on the pIV? If they're engineered pretty well and are in firm contact with the die. I would assume problems with cracking or chipping off the edges of a chip would be gone, another plus.
BTW- does anyone know what the heat spreaders on intel are made of? I assume Aluminum. Any plans for copper?
