I recently added a new intake fan for my HDD cage, and to my surprise it makes noise like a mini vacuum cleaner.
If I remove the fan/place as an exhaust, the noise completely disappears.
So, I guess its the grill tht is causing the noise. So:-
1] If I remove the grill will the fan air intake will be further increased and I will get further lower temps. ?
2] How to remove the grill? Do I need to call sum welder wid a welding machine ? - Image of the grill attached
3] I have this black plastic part on my back exhaust fan, where I can directly insert & remove fan without screws whts this known as? Can I add this on the front to eliminate the noise problem? Image Attached
