Originally posted by: mechBgon
That, or try it on the Promise SATA controller with the Promise controller in straight IDE mode.
err, sorry to bother you, but how do I do that? I tried plugging it into the SATA slot for the Promise controller, and tried installing the promise drivers when promted, but that didnt work. so also, Im thinking maybe my floppy drive might be busted? Or there is either that or some sort of setting I have to change. BIOS does detect the floppy in Boot sequences and the green led on it is on, but maybe the drive is broken, perhaps thats the reason that it wont read from it when prompted for drivers.
Also, does it matter if I dont put the drivers in from the floppy at the very beginning by pressing F6, and do It after it says it can not detect hdd and then press "s"? Because it wont let me press F6 at the beginning for whatever reason.
Originally posted by: OMGoddess
OMG, I just got the same exact board, and I ordered a SATA drive, I am screwed.
You should use the other Makedisk.exe that makes the Promise IDE-mode floppy, not the RAID version (search the mobo's CD-ROM, there are three Makedisk.exe's on it).Originally posted by: User5
Just tried.. Still a no go
Still getting the same "please insert the disk labeled manufacturer supplied hardware disk" after I allready put in the disk with the Promise Raid [378RAID Makedisk] settings on there and press enter. Is this the right disk even? Could there be another problem? And does it matter if the F6 isnt working when its first asked for? Because it eventually asks if I want to press "S" to specify.
Also, do not expect to see anything different happen right away when you press the F6 key at the prompt. The prompt to press S a few minutes later is triggered by it, that's all.
Originally posted by: yankeesfan
the floppy cable is on backwards, that's your problem
