Originally posted by: Link19
Why would anyone in their right mind want to run such a POS OS like Windows 98/ME for hosting a database for more than 10 concurrent users? Windows 98/ME WOULD IN NO WAY be able to handle more than 10 concurrrent users. It would probably sh!t on itself with just more than even one user. WIndows 98/ME don't even belong in the server camp. Windows XP Home Edition would make a much better server OS than POS Windows 98/ME. The only problem with Widnows XP Pro and even worse with Windows XP Home is the licesning that restricts it to 10 concurrent connections, even though it is most likely technically capable of more than 10 concurrent connections.
Use Windows Server 2003 or Windows 2000 Server to host your database. Don't even consider using such a POS OS like Windows 98/ME to host a database. SUch a POS OS isn't even technically capable of being a server OS to host a simple webpage, let alone something that can be as detailerd and resource intensive as a database.
and the turd that wont flush strikes again
While Win98 isn't really suitible for database servers anymore(it's outdated) it can handle more than 10 machines with out any problems (once agoin link19 proves he knows nothing on what he is talking about...do you have you're head up you're ass for the warmth or does it serve a real purpose?)
Win2k is probably a better way to go...much better network capabilities...and you should be able to use the WinXP drivers
Windows 98 has never been suitable for servers of any kind, let alone something as high end as a database server. It is not a server OS. It is only suitable as a low end desktop OS.
Even Windows 2000 Profesisonal and Windows XP Professional, while they are both high end desktop opertaing systems, they are not for high end servers either. You need Windows NT 4 Server, Windows 2000 Server, or Windows Server 2003 for running a server on an OS made by MS.
