tuteja1986
- Jun 1, 2005
- 3,676
- 0
- 0
Yeah, I'd look at new PSU with dual 12v rails. It appears this has only one. I have an Ultra 500W w/ dual rails ... Ultra is not exactly great but it works fine with my HD 4850 and my system is overclocked pretty good. Having a 12v rail you can dedicate to your video card is very important.
There are several good name brand PSUs out there in the 500W-600W range that would probably work well without costing too much.
Actually, multiple rails in general are a bad thing, as they are more susceptible to being overloaded by an uneven distribution of power than a single rail. However, many units labeled as having multiple rails really just have a single big rail internally.
Well here is a good resource:
http://jonnyguru.com/forums/showthread.php?t=3990
Multiple rails are more of a non-issue than being bad, but about everything out there has multiple 12v rails to safety distribute the current load.
Yes, it usually won't make a difference either way, but if all else is equal, a single rail is slightly preferable if only to cover those handful of odd load situations that can exist. There is no advantage to having the video card on its own dedicated rail, on the other hand.
Originally posted by: Martimus
Hard drives not being recognized, and onboard devices not being recognized are both tell tale signs of the powersupply not supplying enough power during startup when the BIOS runs a check on each to detect them. I got tired of being limited to only 2 HD's with my old cheapo PSU's and finally bit the bullet on a PC P&C PSU. Before, if I had more than 2, one would randomly not be detected from time to time.
Originally posted by: Julian1221
Hey guys
I just put my 4850hd in last night and was having issues with it overheating. I read that I should install the Asus fan controller to adjust the fan speed and that fixed my overheating problem. I rebooted the computer and now my ethernet port says its "disconnected" and no cable is found. Am I having power issues with my PSU? It seems like when I reseat the video card the ethernet port comes back until I reboot. System specs below, psu is about 2-3 years old.
AMD 6000+
Asus M2N-E
Asus Radeon 4850HD
2 Gigs of G Skill Ram
Thermaltake 430w psu
X-fi extreme music sound card
You do realize that every PSU that claims to have more than a single rail is just a single rail that is split right? On top of that, single rail PSU's are much better than dua;/tri/quad/etc. rail psu's because you don't have trapped power on the rail.
Besides that it isn't the number of rails that make a PSU better it is the quality of the components used in the PSU and it's design.
Now back on topic.
Hey guys
AMD 6000+
Asus M2N-E
Asus Radeon 4850HD
Are we talking an actual fan controller here? Like a physical one that can be place into a drive bay so you can control your case fan speeds? or Are we talking some piece of software you didn't need in the first place?
To lower the temp's of the 4850 all you had to do was do this
One small adjustment, you don't have to create a profile for that to work, just edit profile.xml which is already there.
I'd also uninstall that fan speed control software you installed.
As far as you PSU is concerned, it is a little underpowered for this setup, if you were to replace it.
I would suggest any of these:
http://www.newegg.com/Product/...x?Item=N82E16817815001
http://www.newegg.com/Product/...89&bop=And&Order=PRICE
http://www.newegg.com/Product/...142556&name=501+-+600W
http://www.newegg.com/Product/...x?Item=N82E16817371007
http://www.newegg.com/Product/...x?Item=N82E16817703005
http://www.newegg.com/Product/...x?Item=N82E16817104050
http://www.newegg.com/Product/...x?Item=N82E16817104048
you quoted me before my edit again.
Yeah, if it doesn't turn back on barring that the fan software didn't mess with any drivers or automatically fiddle with BIOS settings then I would say you would.
Edit:
http://ati.amd.com/support/driver.html
Wrong again. In actuality, nVidia WON'T certify a power supply for SLI unless the video cards are on their own rails......sorta blows your assertion out of the water.
Originally posted by: NVaderJ
Note the 33A rating on the 12volt line. That's the important number. Corsair is a very solid brand.
:thumbsup:
Whether the PSU has 430W, 600W or 1000W, the important number is how many amps COMBINED and SUSTAINED on the +12v rail(s). That Thermaltake the OP has is quite anemic for +12v power. For lots of +12v juice, Corsairs are good, followed by Antecs (whether TruePower, NeoPower or EarthWatts) out of the brands mentioned in this thread.
As for single rail versus dual rail, for the most part that's a non-issue. It "became" an issue due to some FUD a couple years ago from one company.
There is no such thing as trapped power. That's just a bunch of FUD "invented" by a well known power supply company when it switched from a multiple rail setup to a single rail setup.....after it horribly failed in its design of that multiple railed Turbo Cool 1Kw power supply and had multiple failures and such.
Use your brain, not marketing FUD, and think for yourself.
