baumgrenze
[FONT=Arial, sans-serif]I would like to use XP Mode.
I have Win 7/Pro x64 installed, authenticated, and running
Here are my system specs that might apply to my problem:
Board: Gigabyte Technology Co., Ltd. GA-EP35-DS3P
BIOS: Award Software International, Inc. F6 06/18/2009
Processor: Intel Core 2 Quad Q6600 (2.4 GHz) Quad Core
Controller: Intel P-35 ICH9R Controller 82801IR with AHCI and RAID Support
Sapphire Radeon HD 3870 PCIe 512 MB
2 x Crucial 4GB Kit (2GBx2) DDR2 (PC2-6400) DIMM 240-Pin Desktop Memory Modules CT2KIT25664AA800
My BIOS (Advanced BIOS Features) shows that Intel Virtualization Technology.is enabled.
I downloaded and installed XP Mode and it was saved to "Program Files." I then downloaded and installed Windows Virtual PC (I've seen some posts claiming that it should have already been installed as I used a DigitalRiver SP1 ISO as the basis of my installation. It created the folder Program Files (x86)/Windows Virtual PC.[/FONT]
[FONT=Arial, sans-serif]So I found that I had XP Mode under Program Files and not under "Program Files (x86)/Windows Virtual PC.
I dragged the entire XP Mode folder to the latter.
I tried to open XP Mode and the system started to do the whole download from MS again, so I stopped and came here.
Are there some entries elsewhere that don't get moved with the files themselves, registry entries or .ini file entries?
Do I need to do a complete uninstall and reinstall of XP Mode and Windows Virtual PC? I still have the downloaded installation file for XP Mode that worked, I just don't want to dig a deeper hole than I already have.
Thanks,
baumgrenze[/FONT]
Thanks,
baumgrenze[/FONT]
