PLEASE when you POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Will only play Diablo 3 and Maybe world of draenor
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
600$
3. What country YOU will be buying YOUR parts from.
Ontario, Canada
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
http://www.canadacomputers.com/
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I always had AMD I know it is the cheapest. But seems that Intel is now faster.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I intend to Use some parts of my current system
Case - Not sure the name was a generic case for Cooler master I think.
Hard Drive - Western Digital WD Green WD20EARS 2TB 64MB Cache SATA 3.0Gb/s 3.5 - As a storage drive, Would like a SSD for booting and main install of games.
Power Supply - Corsair CX600M
Video Card - Gigabyte HD7850 2gb GDDR5
7. IF YOU plan on overclocking or run the system at default speeds.
I would love to have the option! I used to OC back in my days I know what I am doing but will definitely Read on it if I get something I can OC with.
8. What resolution, not monitor size, will you be using?
Would love to be running at 1920x1080 but right now it says recommended by windows 1280x720 🙁
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
In the next week or two
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
NO
At the end of the day it's your money. There's only so much we can do.
Parts I need
CPU
Motherboard
RAM
SSD drive
Hope I gave enough Info.
600$
Ontario, Canada
NO
Parts I need
CPU
Motherboard
RAM
SSD drive
