Squisher
- Aug 17, 2000
- 21,204
- 66
- 91
How did that happen?
I've heard of pumps getting ripped off their mounts, breaking flanges, etc. when the engineer did not check for free rotation of the shaft before starting the motor. That's pretty bad when the pump (175hp) is moving concentrated sulfuric acid.![]()
Motor was on top of a forging press that just came back online so it was a newly rebuilt motor. The control panel for the press was 20 feet away on the floor, but in the plane of debris when the motor let go.
As to why the motor let go would only be conjecture on my part, but I can tell you it was wired incorrectly in that the mechanical brake on the press did not automatically disengage when the press was started up. I noticed this a few days before when we were setting up the press. I called the electrical supervisor over and pointed it out and he basically wrote it down on his "to do" list, and said he'd get to it later, but for right now we'd have to remember to disengage the brake before starting up. A day later some pretty horrific noises were coming from the press and the machine repairman and I ran to shut it down. The machine repairman figured it was that brake being engaged while it was in full operation.
The day of the accident I had been working on the tooling in that press for an hour before I went home. Second shift came in after I left and 30 minutes later the operator was dead. It is very possible that for those 30 minutes the press was operating under the load to make forgings along with having the mechanical brake on.
