Durvelle27
- Jun 3, 2012
- 4,102
- 0
- 0
Not from his system, but gives you a good idea.
http://www.behardware.com/articles/...rce-gtx-660-asus-directcu-ii-top-and-sli.html
Hopefully guskline/John can tell you if there is any of that dreaded microstuttering!
The CPU can make a big difference, but it still provides a good demonstration of how 660 SLI compares to other graphics cards.
I wasn't intending to draw any comparisons with gusklines system.
I really don't see an FX 8 core that has a decent overclock bottlenecking a pair of 660s. Maybe the physics score but I really think that number is irrelevant in most cases.
It might in the odd Intel favored title, but very rarely.
Hitman and Starcraft are examples.
Not Hitman but starcraft 2 yes.
Hitman i maxed with my old FX 4100 with no problems
If I play Hitman, I'll use rig1 below!At the same clocks Intel has at least a 10 fps advantage, now call me picky but if I went SLI I'd want 60 fps not 50.
http://www.techspot.com/review/608-hitman-absolution-performance-benchmarks/page6.html
While it is true, it won't bottleneck them very often, and you may not even have a game that does, every once in a while, a game comes along and does.I really don't see an FX 8 core that has a decent overclock bottlenecking a pair of 660s. Maybe the physics score but I really think that number is irrelevant in most cases.
You will see that difference when playing Multiplayer and up to 64 player maps.
For the single player game benchmarks there shouldn't be much of a difference with his CPU.
But, it'd be interesting to see if you are CPU limited in SLI, compared to his machine or your other rig. I'd be curious to see the results, if anyone feels like doing all that work.![]()
I agree Revenger. In Benchmarking my 3770k @ 4.4ghz scores higher than the FX 8350 @ 4.6ghz and the FX 8320 @ 4.3Ghz.
However, in gameplay it's not as noticeable. All three rigs play the games I use fast.
I did notice in BioShock Infinite that with a single 660 in the 8320 rig at 1920 x 1080 I lowered all the "eye candy" to have a smoother game play. Now that the rig is running 660s in SLI I can crank up the candy without the lag.
Thanks for that info...! I was kind of curious if the FX would bottlenect that much GPU power. I always felt that Vishera's performance was ok... not great, but reallly not nearly as bad many seem to think. The real problem with AMD's lineup is the power draw, not horsepower.... my opinion of course.![]()
