Fox5 you also forgot what this Topic was about .So you mistakenly invoked Cortex 9 cores as a defense . So sad. The VR 545 uses dual cortex 9 cores . So its really looking bad for your side of this debate. You have completely defeated yourself in all manner . I sugjest you brush up on your debating skills , Befor playing with Fire.
You are quite the fire, aren't you?
This argument started about the badassness of the powervr sgx graphics, and transitioned to the viability of atom in smart phones.
The name of the graphics core is SGX545. It can be paired with any processor a company so chooses, which will most likely be Cortex A9.
Cortex A9 has nothing to do with graphics. In terms of raw power, Tegra 2's gpu will beat SGX545, but it's not aimed at the same market.
Cortex A9 and SGX545 will have fantastic power efficiency, and good cpu performance. They will be sized/priced right to go into most smart phones.
Tegra 2 (with its Cortex A9s) will also have fantastic power effiency, good cpu performance, and desktop level gpu performance. It will also be much more expensive. The extra cost/size will keep it out of most phones.
Medfield will be even bigger than Tegra 2. It may be reasonably priced due to intel's manufacturing advantage. It will not have a major cpu performance advantage. It will do much worse in power consumption, as there is a large penalty to pay for making a competitive x86 part in a market it wasn't designed for. Graphics performance will be inferior to tegra 2, and if Intel treats the drivers the same way they treated the PowerVR tech in the GMA500, it will have massively inferior performance. It will however be competing for the same markets as Tegra 2.
Medfield +1 or +2 will be much more interesting products, if Intel can lower power consumption to match the competition.
But you know what, I take back everything I've said in this thread. You win, and let's be done with this.
Edit: I need to make a specific correction.
Tegra 1 was rather large and expensive.
Tegra 2 is comparable in size to the TI OMAP cores it will be competing against. Or at least one specific Tegra 2 chip is, the Tegra 1 had multiple SKUs, the Tegra 2 probably will too.
