I'm worried...lga 1155 mobo with lga 1156 heat sink?
csj0952
45
I have a gigabyte p67a-ud3-b3 mobo which says it's lga1155
My heat sink is a xigmatek dark knight s1283v
it says on the box that it's compatible with lga 1156
My CPU is i5-2500k lga 1155
Do I need to buy a new fan?
BoomerD
66,579
14,981
Nah, you're good. Both sockets use the same mounting pattern...and (IIRC) the 1155 processors run a bit cooler than the 1156 processors.
I don't know how good that particular HSF set up is personally, but it gets OK reviews.
http://www.overclockersclub.com/reviews/xigmatek_dark_knight/
I suspect that as long as you don't push an overclock too hard, it'll work just fine.
dma0991
2,723
It will fit like a glove. No issues whatsoever when I tried installing a CM Hyper212+ meant for the LGA1156 on a LGA1155 board.
Morphx2
173
I just installed a Xigmatek Gaia on a 1155 board last night. I had your same question, googled it, and as it turned out people were correct in that it is the same as the 1156 holes.
Morphx2
173
punch down screws? Mine had T-screws, but i totally screwed them in the wrong way, but still worked. After I screwed them in, I realized "Hmmm, 'T' screw. Probably should look like a T when screwed in"
Morphx2
173
ahh, gotcha
Installing those stupid anti-vibration things into the fan was the hardest part. My thumbs were hurting after pulling them through
