buy this one, its a little over you price range but well worth it
http://forums.anandtech.com/messageview...atid=45&threadid=1467537&enterthread=y
Originally posted by: qbackin
Originally posted by: Insomniak
Chieftec Dragon was #1 back in the day, and still holds up very well now. A modern variant with 2x120mm (intake and exhaust), 2x80mm (side and blowhole) instead of 4x80mm would be right up there with the best.
Is there one like that? Or are you suggesting modding the case?
What is the value in doing so? (Asking seriously here.) Is there not enough cooling using the 80mm fans, or is it a noise question? Are 92mm fans really that much quieter? Why not just use quieter/undervolt the 80mm fans? And for the HD bays, it seems like the 80mm fans are the "perfect" size, I don't see how 92mm ones would fit. I agree with the additional cooling value of the blowhole, I bought my Codegen specifically because of that. Not sure what the major value is in a full-tower though, as there is usually more than enough room at the back to add additional case exhaust fans which are nearly as effective. But for a mid-tower, the room for those on the top back-panel simply doesn't exist, so a blowhole is an excellent solution in that case.Originally posted by: charlietee
One thing really great about that style case be it Chieftech, Antec...They are easily modded...Can put 4 92's in one with a pair of side cutter pliers, flat bastard file and a drill. I put a 92m/m blow hole...
