Last year I was about 200 lbs. I cut down to 160 in ~4 months, and was doing fine - flat stomach, looked alright. Since then however I've stopped working out and eating right, and am up to 170. The problem is that I look quite a bit worse than when I was at 160, to the point that if I get back down to 160 I doubt I will look as good as I did last year.
My question is, what should I do first - gain some muscle/weight, say to 180, then start cutting to 160ish, or just go straight for the cut, perhaps down to 150ish? I'd like to see definition in my stomach area again.
I have read the fat loss sticky as well as Stronglifts, but neither really mention what to do in this situation - Stronglifts says for the "skinny-fat" person to first gain weight then start losing, but the weight he gives as a minimum is about what I am at now (i.e. according to Stronglifts I should be cutting immediately).
Thoughts?
Thoughts?
