Originally posted by: Aharami
im waiting for AMD to come out with something that beats the c2d. That should make the current top of the line AMD CPUs prices to drop considerably. That will be the time when I upgrade with current top of the line AMD CPU
Originally posted by: AdamSnow
Just got my new rig as well...
E6600 C2D
2gb PC8000 RAM
2 Seagate SATA 400gb drives
8800GTX video card
cant wait to get it all together!
Originally posted by: thehstrybean
You belong on AT...
Originally posted by: AMDZen
This processor for 185
http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
Plus this motherboard for 119
http://www.newegg.com/Product/Product.asp?Item=N82E16813128017
Prices will drop a little when the new ones come out
http://www.dailytech.com/article.aspx?newsid=5414
And there will be an even less expensive processor as well. I see now the 3.0 Ghz are running 90 now so yea, a C2D is going to run you twice as much. As someone else said, you could consider a 939 build and get a nice Opteron for about the cost of that Prescott
See, that?s a good recommendation. Even though it?s one of the cheapest solutions for a Core 2 setup right now, this setup will easily OC to over 3Ghz+. Bearing in mind he already has DDR memory, so he would need to purchase some decent PC2 6400 ram too.
Surely there must be some bundles available, with similar hardware included?
The Prescott supported DDR2 800, I don't think there were any motherboards that suppoeded DDR although that may have changed - so chances are he already has DDR2 800 memory and depending on the memory it will probably be able to go faster then its rated speed. To really overclock, yea he would probably want some DDR2 1333 - but it sounds like hes a novice and may not want to overclock too much any way
