I'm having leakage problems
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
I mentioned two ways the top is attached - I neglected the 3rd. Whirlpools control panel is held on by 2 screws on the back.
Here's a video of a pump being replaced. Yes, it's this easy to replace parts for most brands of washing machines. Another very common repair is the coupling from the motor: 2 plastic pieces with 3 holes each & a plastic thing between them which couples them together - another $10, 10 minute repair (if that) and reason many people just go out and purchase a new washing machine.
http://www.youtube.com/watch?v=Ue4pkhSJw7U
(he sounds like a goofball, but you can see how simple a washing machine comes apart - definitely worth knowing.)
I have zero experience with front loaders. I don't care that they use less water. But, if repairs are more difficult, then that's a huge reason I wouldn't purchase one. Our last washing machine worked great for over 20 years. During those 20 years, I replaced the coupling twice, and the dog teeth (or whatever they're called) once. Ran like a brand new machine after those dog teeth were replaced. Unfortunately, the room it was in got really cold & everything froze. The motor overheated when trying to run, etc. - not worth bothering with at that point. I saved a few parts though. :)
Paperdoc
2,498
373
I've fixed various sources of leaks. The most recent, on a pretty old machine, turned out to be a leak from the pump. I had to open the covers on the back a bit and watch it operate to see where the leak came from. In this case, the water came from a hole in the side of the plastic pump case. I recognized that, in fact, the real problem was that the shaft seal above was worn out to allow water to leak down and damage the bearing below. So I just bought and installed a new pump. Problem solved.
Beev
7,775
Sir, are you aware that you're leaking coolant at an alarming rate? Let me just patch you up with some hot resin.
