Aharami
i think its too boomy. I was looking for tight base. I dunno if its the enclosure I built, or whether its cuz the 10w7 i bought was used...
the enclosure I built is more or less to JL recommended specs: 1.32 cu ft internal volume. JL recommends 1.25 cu ft internal vol without taking into consideration the sub displacement. Since the cone displaces .09 cu ft, i made the total internal vol of the sub as 1.32 - 1.34 cu ft. Its a sealed box.
Now im thinking maybe I should've made the box a bit smaller - maybe 1 cu ft total internal vol (so after cone displacement, I'd be left with .91 cu ft internal vol)
Would the base response get tighter if I reduce the size of the box? Friend has an Alpine type-X and he claims that his sub got a lot tighter after he reduced the enclosure volume.
Also I should mention that I JUST finished putting it in and hooking everything up. So I havent had the chance to play with the settings on my amp. I have an Alpine MRD-M1005 powering the 10w7.
