GTaudiophile
You never answered my 12:06am post.
Originally posted by: Eli
What about a home stereo system?Originally posted by: rudeguy
Originally posted by: TommyVercetti
Recommend me a stereo system for my car. It should play MP3s, and must have manual seek on the radio. Auto seek won't cut it, cuz I live way out of town, and reception is weak. Auto seek doesn't pick up the radio.
jvc or pioneer....pioneer if you want good sound quality, jvc if you want bells and whistles
I was browsing the stereos at Fred Meyer.. there were a couple I would consider, but I couldn't tell if any of them had surround sound. I want a stereo that I can hook up at least 1 more pair of speakers. I hate the bubbly look of most new stereos. I also hate the pre-set equalizers. :| What happened to manual levels?!
What can you recommend? Right now I have an old-ass Studio Standard by Fisher with 2 Intrada 10.3 cabinets each with a 10", 4" and 3" speakers, 30 - 20,000kHz, Crossover at 1.5 & 5kHz, 8 Ohms. It sounds OK, but it's really old.
I'd like to be able to use these speakers along with my new stereo, and possibly some other ones I have.
Originally posted by: GTaudiophile
Best alternative to Monster cable?
And who do you work for? BB?
Originally posted by: v3rrv3
Electronics bud, not encoding pr0n 😱
- Kevin
Which would you pick from this list of higher-end speaker brands:
Bose
Boston Acoustics
Klipsch
Mirage
Sonus Faber
Vienna Acoustics
Originally posted by: simms
Another serious question: What's the difference between 16:9 and 4:3? They go down to the same fraction anyways. I don't see how different multiples correspond to widescreen/fullscreen.
BWhahaha.. 😀Originally posted by: jacob0401
you failed math...didn't you...
What is Bose doing there?Originally posted by: GTaudiophile
Bose
Boston Acoustics
Klipsch
Mirage
Sonus Faber
Vienna Acoustics
You guys just got pwned by his sarcasm. 😛 😛 😀Originally posted by: simms
Depends, you can get 45% on TV (Mitsu RPTV). Sometimes, you can get up to 65% on speakers.Originally posted by: rudeguy
25% on electronics, 50% on speakers, TV's differ from brand to brand and depending on the size, but in general 30%Originally posted by: dmurray14 what is the markup on different products?
Well, since our resident expert don't answer this, I will. First of all, Bose doesn't belong there.Originally posted by: Legendary
This I would like to hear an opinion on.Originally posted by: GTaudiophile Which would you pick from this list of higher-end speaker brands:
Bose
Boston Acoustics
Klipsch
Mirage
Sonus Faber
Vienna Acoustics
Buy a new VCR, they're a dime a dozen. Don't spend lots of money on a VCR, think disposable.Originally posted by: bleeb
My VCR is currently experiencing some technical difficulty. Specifically the "white" of flesh tones is way high. I've tryed this on all the tapes at home and I am unable to unadjust it on the VCR and the TV. Any ideas of how to fix it?? BTW: we have a Panasonic PV-V4603s VCR and a HOME Theatre with a TON of wires and connections. Can that be the problem? Also our Sony 60" projection is going on the fritz lately
I don't know what are available for you, depends on what your receiver is capable of, is it a digital receiver? Because if you have Cambridge PC speakers for fronts, then I would say that it is not important what you should have for the rear, anything that put out sounds should be fine.Originally posted by: moonshinemadness
So presently for my surround satalite speakers i have cambridge soundworks pc speakers hooked up to a sherwood reciever. I want to replace the rear ones with some wall mounted or bookshelf speakers. What would a good set to go with? Preferably i want to spend less that 150£ ($200?) on the two
