Keysplayr
Originally posted by: apoppin
Originally posted by: Keysplayr
Originally posted by: brblx
to apoppin's credit, i went benchmark diving and it DOES appear that the 4870x2 is more CPU limited than the gtx280. so sorry for that, duder. but, it is still probably a software or driver-related occurence, and i don't think it's related to the OP.
but yeah, he can try kicking it up 4-500mhz and see what it does. the problem is that if it DOES improve, there's no gauge for how much it 'should' improve. even with another issue, he'll probably net a few fps more.
i'm sure the OP has tried this, but since i didn't see it mentioned- you did check all your driver-level settings, right?
Yes, it is CPU limited. You put a GTX280, 4890 or 4870X2 is a 1GHz PIII system (as if that were possible, but for example purposes) The all would be accutely limited by the CPU. All three graphics cards would have the same exact ceiling of fps in a given game. None would do worse than the other, nor would they do better. You put these same 3 cards in a 4.0GHz i7 rig, and the 4870X2 would dust them both. So yes, the 4870X2 would benefit from a faster CPU. But unless Xfire isn't working as Zap mentioned, or there is a driver/OS/hardware problem, there isn't any reason a 4870X2 would ever perform slower than a GTX280/4890 in any system where the system remains the constant.
the OP has run away .. and what the hell does "choppy" mean anyway?
- he left us with NOTHING to go on .. but a discussion
ANYWAY -
q9550s at 4.0 GHz [Very high/4xAA/16xAF/16x10]:
<< 4870-X2 = 25 min / 33.77 average/45 max
q9550s at 2.6 GHz [Very high/4xAA/16xAF/16x10]:
4870-X2 = 17 min / 27.92 average/42 max
i'd say it is a little choppy with the slower CPU down from 33.72 > 27.92 average
Also, by my testing at MAX detail, most of the work has been offloaded to the GPU
- i live this stuff now 😛
So what? You have MISREAD the original post - what you are saying has nothing to do with anything he stated herethere isn't any reason a 4870X2 would ever perform slower than a GTX280/4890 in any system where the system remains the constant.
Crossfire is working fine .. there are no driver issues in my PC
-the OP should at least attempt an OC to check out the performance differences
In the immortal word of Zstream..... *facepalm*
