I'm about to overclock an X2 3800+
Smartazz
6,128
Originally posted by: inspire
You mean - 'Is it possible to overclock without doing it in the BIOS?' Yes, it is, from what I understand, but I've never done it. Keep your load temps under 55C and you should be fine. Just keep an eye on it - you may run into temp problems as you clock higher. Don't be afraid to back the voltage down if you're pushing the temp envelope.
55C? I was planning to make 60C the highest temps I would let this thing hit. Well whatever is safer for this chip I suppose.
edit: How do I stress test both cores at the same time?
edit: It hit 60C, so 2150MHZ will be the hardest I push this chip without further cooling.
imported_inspire
986
60 is okay, but I wouldn't want mine flirting too close to 60 - I just said 55 to be extra extra careful ;)
If you're using Stress Prime 2004, you can Set the CPU you test on using a drop down box. If you're using Prime95 - check here - that explains how to stress both cores.
If you want to try for more, you can back your volts down and see if it will go any further.
Smartazz
6,128
ok, so I set it to 2200MHZ, right away it flashed to a blue screen and said beginning phizical dump.
imported_inspire
986
:Q OH NOES! Well, that's not a bad run. If you ever end up looking for a better cooler, I love how quiet my Scythe Mine` is. Sorry it didn't work out any better for you, smartazz - good luck!
Smartazz
6,128
Well, thanks for your help, I think I might wait until this cpu needs an overclock before I start the heavy overclocking with a better cooling system, maybe I'll pick up a Scythe Mine, keep me posted how your overclocking goes, thanks.
akshayt
Banned
Feb 13, 2004
2,227
Mine is Asus A8N E. If it is unable to boot into wincdows it just restarts and I can change the BIOS again. No CMOS worries for me.
