phucheneh
- Jun 30, 2012
- 7,306
- 5
- 0
It was sarcasm. ;P Fluke's pretty much the standard for electrical work of this scale.
The 'magic' comment was also some mild sarcasm. It's not magic at all; it's physical law.
If you're looking for mV losses, I would assume you're dealing with small, sensitive circuits. You likely do not encounter what I'm describing because the small ohmmeter current is not in such stark contrast to the amount of power the circuit may carry during normal operation.
I really can't put it much more clearly than the water analogy. For most people, equating electricity with water works pretty well, since one of them is something they're familiar with that they can see.
If you don't feed the circuit enough electricity to actually test it in a real-world kind of way, you're not going to get real-world results.
Example: I have an 18ga wire with 3/4 of the strands cut at a particular location. Guess what? That 18ga wire is now ~28ga or so. The resistance of that bad spot in the wire will be directly proportional to the amount of current it tries to carry. Feeding a 2 ohm load with 100v? Your shit's not gonna work. 100 ohm load with 2v? You'll still get plenty of electricity.
I think the problems comes from people thinking of resistance as a fixed value. That's fine when you're talking about the load in a working circuit. But points of extraneous resistance are not going to be constants. The more power you attempt to run through them, the more voltage the trouble spot will consume (and heat it will produce- because it's basically a resistor now).
