If the sun stopped producing energy how long would we live?
Originally posted by: Descartes
The ether would absolutely have to be rigid in order for 'c' to be 3x10^8 m/s! The medium would also have to be supple enough that the celestial bodies move around unimpeded. Also note that many, many tests have been performed pre-Maxwell to determine the speed of light by using the ether as the ultimate body of rest. As you've said, yes, we haven't quantified any such medium, and thus to say it exists is moot.
well, it's relevence to this argument is moot, because we know for sure that heat energy transfers through space. so what else is there to know for the purposes of this argument?
It's great to see someone of such intellect resort to ad hominem attacks. That really says a lot of your statements.
if you had understood why i used it (cause i spelled it quite clearly for you) then maybe you wouldnt have questioned it, and i wouldnt have gotten disgusted by your questioning. anyways, fine, let's hear why the heating and cooling properties of a white dwarf are so much different than of earth? in this scenario, both are dealing with only a finite amount of heat energy for the rest of their existence. tell me why the analogy is unfitting here?
I'm approximating here...
The sun is about 100 times the diameter, and the white dwarf is about 1/3 the diameter of the sun. You were drawing a parallel between the time a white dwarf maintains its relative luminosity magnitude to that of our earth; this would be roughly analogous to saying that a snowball the size of the earth will melt like a snowball the size of my fist. Granted, the thermal properties are the same, but only so relative to the mass. Such a comparison in any regard was, in my opinion, pointless. If you were simply stating how heat transfer works, then ok, but we're referring to the relative time required for thermal equilibrium here.
Anyway, this is getting frustrating. If you wish to further our discussion with more ad hominem please PM me instead
:beer:😀
Originally posted by: Eli
I think the first main concern would be the temperatures.
I can imagine the air temperatures falling fast. That, coupled with no sun, would basically wipe out plants.. the food chain would collapse.
Fortunately, we would still be able to generate energy, grow (a limited number of) plants, animals.. so food would still be available, if not very hard to come by/expensive.
I think we could sustain at least small pockets until the atmosphere became inhospitable.
But we would just be prolonging the enevitable. Everybody would perish eventually.
With sufficient planning I think life could be sustainable for a relatively small number of people (less than 100,000).
Yes, perhaps. It would take some serious planning and building though.
You would need an entire planet's ecosystem(at least enough to sustain itself) in a rather large biosphere..
You would not need the entire ecosystem.
1: Power - Nuclear
2: Heat - Electric or steam from nuclear power
3: Air - Use electrolisys to produce oxygen from water
4: Food - Stockpiled food until plants could be grown with artificial light.
Because space isn't a vacuum 🙂 Anyway, I've given myself a headache with the arguments.
<changingSubject>
Did you know Saturn will be at opposition on the 31st? I'm able to get a worthwhile view of Cassinni's divisions in my 8" dob right now too 😎
</changingSubject>
Originally posted by: PipBoy
Originally posted by: moonshinemadness
If the sun died out, we wouldnt know about it for 30 years would we? Dues to the distance? Am i wrong?
do you live in the vicinity of Alpha Centauri?
wow! thats one craaaaazy wireless connection....to be connecting to ATOT here on earth
:beer:😀
i'm not saying we would continue to thrive for thousands of years more (like a white dwarf's heat) but we wouldnt just blink out of existence in 3 seconds like you said in your first post. i'd give the majority of human life on earth... a week. i have no idea how much or little heat transfers through the crust of the earth, but i pretty much know there's nowhere near enough to sustain life on the surface of the earth. maybe if we burrowed about 50 miles, we might stand a better chance.
We got Walleye, who is clearly not as informed on this topic as Descartes, pulling personal attacks in statements that don't even support any opinion or theory.
Excellent tactic.
I'm sure it works well in high school.
Even Alpha Centauri is only about 4 light years away...
About white dwarfs, I'm not sure that they're not doing anything to produce a small amount of heat. A star remnant is probably radioactive up the wazoo since it was carrying on nuclear fusion for so long. So a slow radioactive decay should be possible. Also, isn't it possible that there's still a little bit of fusion going on in the core?
No, they expell their shells (if you allow me such a nondescriptive term) and thus no longer have the mass/fuel to support nuclear fusion.
The earth would not cool and precipitate the atmosphere in mere seconds. Without trying to remember my thermo dynamics, the specific heat and transfer rates of the atmosphere I would say we would have at least a week before the atmosphere started precipitating, and probably much longer. If humanity can survive in space we could survive on a dead planet. The real question would be would there be enough time to get enough people into space worthy shelters with the equipment to survive the long haul in time to save the species.
We can engineer an environment to survive, that is without a doubt, it would simply be a question of the time necessary to construct that environment. Of course this is all kinda mute because the sun would die rather violently and vaporize us and the planet in the process.
<changingSubject>
</changingSubject>
you got an 8"?
<-- jealous
heh.. it's cool, i got a 5" schmidt cassegranian. 🙂
that's correct. they have no nuclear reaction anymore, the only reason they exist is because of the massive amounts of heat, that they'll slowly radiate off for the next long term of their life cycle, till eventually they become a dead rock. (i think)
you probably didnt realize it, but the voyager missions were to get wireless internet access to the outer solar system. 😛
pretty long if prepared. Use nuclear to provide heat, electricity, maybe some subterranian greenhouses or something, wear lots and lots of layers when going outside, go to wisconsin, grab a bunch of frozen dead cows, make steak, mmm, steak. I like steak.
These discusssions are synonymous to "Pinto" AKA Larry in Animal House getting stoned for the first time and wrestling with the concept of us all being atoms in a giant's fingernail 😛 this sums it up
Just 5-6 ft deep the Earth maintains a constant temperature of some 5xf. AFAIK that heat comes from the Earth's core(correct me if I'm wrong), if so, then survival maybe much more likely than some may think. If not, we won't be dead instantly, but only a select few would have a chance of surviving for any length of time.
First off I have not read every post in this thread, so perhaps this has been said. Sorry if that is so.
Consider that every night the surface of the earth is exposed to deep space. Further the polar regions are exposed to deep space for extended periods of time and get no where near absolute zero. So if the sun were to stop producing energy the earth would not instantly freeze. The core of the earth is quite hot so the the earth would stay warm for probable centruies after the sun went out. How long it could maintain life as we know it is a different issue. We rely on the sun for our food, what plant life was on hand at the time the sun died would be the last that could exist.
There would be considerable stores of food and fuel so for people who had acess (or control) of these would do pretty well. Using the artic regions as an example you can bet that within a few weeks the temperatures would be well below zero (F) so we would loose all free water, all plant life would be dead and it would, of course, be pitch black out side.
Our civilization could not last but a matter of weeks, the power grid and infrastructure would collapase and centralize control would vanish. It would soon be to cold to use most fuels so by 2-3 months few would remain.
I do not see how life could last more then 6 months.
Originally posted by: FFactory0x
Guys Seriously I dont think anyone except a few know what there saying. After the 8 min are up we will instanly freeze like icecubes. No grdually but instanltly. Absolute zero is like 10000 below zero. Even if you ran to get in a tunnel you would freeze like the t-1000 mid run. No one on the surface would make it!!!!!!!!!!!!!!!!
That was the stupidest thing I´ve ever heard. Absolute zero is -273c.
You´re stupid If you think the temperature would drop to -270c or whatever instantly, it would take long.
The distance from the sun to the earth is considered a single astronomical unit, and it would take the last bit of light from the sun about 8 minutes to reach us. This is of course assuming that the sun simply "burn out" and didn't follow the empirical stellar evolution of a white dwarf. Assuming that, the ambient temperature would be little more than absolute zero, Kelvin; roughly the same temperature as observed in the cosmic microwave background. Since the 2nd law of thermodynamics says heat transfers spontaneously from a hot to a cold medium, I would *think* the thermal capacity of the earth would be high enough to sustain an existence for a couple of seconds? It can be quantitatively measured, but I don't know what the respective values.
Bullsh!t
The sun is NOT a white dwarf star and thus would not collapse upon itself after radiating all its energy. Also, the 2nd law of thermodynamics is a general rule that applies conceptually but doesn't take into account several factors in physics. For starters, there will have to be a coefficient of heat transfer out of the atmosphere multiplied by the distance between the surface of the earth and the outside of the atmosphere, multiplied and surface area of the earth. Take that into account, add into the fact that >70% of the earth is water, and that water is fairly effective in retaining heat. However, i like how you stuck in the words "cosmic microwave background" despite the fact that microwaves really only radiate from stars.
define long?
define long?
I don´t know. It would probably go down to -50c after a few days.
