If someone cuts your brake line, and you lose the ability to brake your car...
Legendary
7,019
I'm curious because I see this on TV all the time, someone is murdered because someone cuts their brake line...is the e-brake connected to the same line? Or will pulling it engage the brakes and stop your car?
DainBramaged
23,454
41
Yes, it will slow your vehicle. It is cable based and does not rely on the hydraulics of the brake line.
schneiderguy
10,801
i dont think it will stop the car. ive driven 10 miles with the ebrake on :eek:
i think you're supposed to put the car in neutral to stop it if your brakes fail.
Rubycon
Madame President
Aug 10, 2005
17,768
485
One thing's for sure. If they sever your brake line, they break your car. :p
jlee
48,518
223
Putting in neutral isn't going to slow you down much..at all.
Downshift + ebrake FTW.
Ricemarine
10,507
Well... if your brake line is cut, then pumping the break is no use...
I do believe you're supposed to shift to neutral and pull the parking brake, and pull off when safe.
Or go up those hills which were meant for brake failures.
Kalvin00
12,705
+1
except the ebrake on my tacoma sucks balls, lol
Heisenberg
10,621
Yes, as said above the emergency brake uses a cable. However, if someone knows enough about cars to cut the brake lines, then there's no reason then wouldn't just cut the e-brake cable too.
DainBramaged
23,454
41
Neutral won't do sh!t. Downshift as far as you can + ebrake.
jlee
48,518
223
+1
Yours too, eh? So it's not just me. Perhaps it needs adjusting..haven't bothered to look at it yet...
Kalvin00
12,705
heh. mine is useless if im parked on anything fairly steep at all. just gotta hope it doesnt pop out of gear :D
thehstrybean
5,727
Runaway truck ramps. Those things are a blast. I waited until it rained really hard here, then found ramp that was all muddy and nailed it. It was a blast...
DainBramaged
23,454
41
I can picture you getting out and putting cinderblocks under your tires. That would be LOL.
jlee
48,518
223
Though really, your brake light would be on as soon as you started the vehicle...and if you use your ebrake/parking brake when parked, you would notice the lack of tension if the cable were to be cut.
LOL...yep -- I stood on my tire once and the truck started to creep backward. I immediately hopped off and put it in gear. I had to park on a steep driveway once..brake wouldn't hold it, and leaving it in gear didn't feel too stable either. I think I put it in 4wd & then in gear..that did the trick. I really should check my rear brakes..
jlee
48,518
223
I used to drive a work truck for a friend of mine....the clutch pedal was wack and was very difficult to depress enough to hit the clutch safety switch (to start it), and his parking brake didn't work. So we almost never shut it off (F350 turbodiesel), and had to put a wheel chock down before I got out..
thescreensavers
9,916
couldest you in theory put your car in revers and then I bet it would slow you down a whole lot. rather ruin your car then your life
JulesMaximus
74,562
969
I find it hard to believe that anyone of driving age is this stupid.
JulesMaximus
74,562
969
+1
You need to have it adjusted. It's painfully easy to do and it's very worthwhile.
Skeeedunt
2,777
no you don't
really though, why the hell would anyone think putting the car in neutral would slow you down?
chambersc
6,247
Think about this. If someone cuts your break line, you would know it really fast. When you back outta the parking spot at like 1 mph, you would realize that you couldn't break. I don't see how these "driving 50mph and breaks are out due to malice" are possible.
benliong
1,153
Originally posted by: mar23
i drove my car with a broken brake line
My friend did that once, and I was on the car. He kept engine-braking to slow down. Some drivers use that to save on brake pads.
Lithium381
12,452
near impossible to do at any real speed, reverse doesn't have those syncro things so you'd just get a bunch of grinding
Perknose
Forum Director
10,484
147
PLUS, in an emergency situation, turn off the ignition, then you'll get FULL engine braking and your e-brake will still work -- just remember you're gonna' have to manhandle your now non-power-assisted steering.
