If someone cuts your brake line, and you lose the ability to brake your car...
Hossenfeffer
7,462
Originally posted by: Heisenberg
Yes, as said above the emergency brake uses a cable. However, if someone knows enough about cars to cut the brake lines, then there's no reason then wouldn't just cut the e-brake cable too.
I KNEW I forgot something..... GAH!
jlee
48,517
223
Originally posted by: Perknose
Originally posted by: CadetLee
Originally posted by: schneiderguy
i dont think it will stop the car. ive driven 10 miles with the ebrake on :eek:
i think you're supposed to put the car in neutral to stop it if your brakes fail.
Putting in neutral isn't going to slow you down much..at all.
Downshift + ebrake FTW.
PLUS, in an emergency situation, turn off the ignition, then you'll get FULL engine braking and your e-brake will still work -- just remember you're gonna' have to manhandle your now non-power-assisted steering.
Turn it off and immediately back to 'on' without starting again or your steering will lock. Bad situation..
Syringer
19,333
Can you do the same thing to a new Mercedes, or a car that doesn't "mechnically" brake your car but rather sends an electronic signal to provide the mechanics to stop it?
cessna152
1,009
I had the brakes fade on me while driving home in the rain at night. Was very very scary. I kept my hand near the e-brake handle the rest of the way home. In retrospect, I probably should have pulled off and called a tow truck...
Perknose
Forum Director
9,839
Only if you turn your steering wheel full lock, son.
OrganizedChaos
4,524
i've said this many times now OFF does not equal LOCK. on my explorer and my jeep the ignition goes ACC>LOCK>OFF>ON>START
are foreign cars different or something? i can start and stop my engine as i please without locking the stearing column. in fact because i drive an automatic i CANNOT lock the stearing column without the transmission in park. even with a manual theres no reason you should have to turn the ignition to the lock position.
jlee
48,517
223
All I own are Toyotas, and I'm almost postive they lock on accessory. I have no 'lock' position -- just off, acc, on and start.
jlee
48,517
223
Mine will lock without turning full lock. Perhaps Toyotas are different. I'm not making stuff up, if that's what you're implying.
Kenazo
10,429
He's just implying you're too young to know your sh!*.... ;)
AgentJean
Banned
Jun 7, 2006
1,280
If your break lines are cut and the Ebreak doesn't stop you, just throw the car in park.
Just make sure your inertia dampeners are set to full power before doing so.
jlee
48,517
223
Must be. Heaven forbid I'm actually somewhat familiar with my vehicle.. :p
Y'know, I'll have to check tomorrow to be 100% sure; it'd be awfully embarassing if I was wrong. :eek:
Kenazo
10,429
:) It's the internet. No one will ever know if you're wrong, unless you bring it up.
Shawn
32,236
53
Shutting off the power FTW! You will lose power steering, but that's not really a big deal.
Kelemvor
16,928
8
Many people don't put their e-brake on hard enough when they set it. If it'son fully, your car won't be moving at all. If your brakes die, you shoudl basically engage the e-brake slowly a bit at a time.
You shoudl NOT put the car in neutral as that will just make you coast. You should downshift in a manual car or shift to 2 or 1 if you have those in an automatic car. I wouldn't turn off the engine because you'll need to steer when you get ready to plow into something...
Sep 29, 2004
18,656
67
I found out the scary way.
1996 hevy truck had a leak i nteh hydrolics.
Went to stop and I freaked out. I didn't stop. Turns out if you press the peddle to the floor it is tied into the parking brake as a back up. I was in such a panic, if it wern't set up that way, I would have slid into traffic.
jlee
48,517
223
And if I bring it up and want to cancel it later, it was my 13yo cousin on my computer, right? :D
Kenazo
10,429
Precisely, I think you're safe.
Perknose
Forum Director
9,839
Nah, come to think of it, you're probably correct. Of all the vehicles I've had, some did lock up short of full lock. My bad, good additon. :eek:
Jeff7
41,596
19
Structural integrity field too, or else you're going to have some warp coils rip themselves out of their bulkheads.
DrPizza
Mar 5, 2001
49,601
166
111
www.slatebrookfarm.com
Hmmm... no one mentioned it, but I was pretty sure that they haven't been called "emergency brakes" by the automotive industry for quite a few years. I believe they're referred to as "parking brakes."
goodoptics
2,652
They don't lock at "ACC" position. As soon as the key is turned slightly away from "OFF", the steering wheel will remain unlocked, providing the ignition lock mechanism is in good condition.
OVerLoRDI
5,490
4
down shift into a lower gear + emergency brake. Although that kind of braking only works on manuals.. Maybe on automatics if you turn off over drive?
jlee
48,517
223
I could've sworn my truck just did yesterday. Slightly away from 'off' is 'ACC'. :p
You can still downshift an automatic.
