Originally posted by: Tiles2Tech
1) Use whatever resources you can to resolve the issue - even asking for assistance in on-line forums.
2) Nobody knows *all* the answers. However, your boss will just usually expect you to know where to look to find the answers.
Originally posted by: skace
Working in the IT field is not about knowing every answer, but being able to find the answer or tackle a problem in which you might not know anything about going into it. A big part is being able to admit when you don't know the answer also, too many people like to try to make up an answer on the spot because they simply don't know, this usually puts them in a hole twice as deep.
I agree. The more I learn, the less I realize I know. I was told in a training class that W2k took ~10,000 people 5 years to write (10k over 5 years, not 10k all 5 years). Oh, and that's just the OS, I'm sure your also running 3rd party drivers and software. Who knows how many people developed all that. How the fvck could 1 person possible know 60% of 10,000 people's input? You can't, no one does. When some asks me, why did that happen, I'm generaly thinking "how the fvck would I know?" and I have been doing this a while.Originally posted by: Jero
Originally posted by: YoYoBabyYo
ditto with what everyone said above, but an IT person should know most of the solutions (i would say about 60%, perhaps too low).
not really. at the speed things change.....no one can even know 60 percent.
Even if you said you know 50 percent I'd say your full of it....
In all computer related things...i MIGHT know 20 percent TOPS (and that is probably pushing it)
The trick is, you research things, you learn things, you increase your knowledge, and write things down.
you forget things, you go back to research
You should know how to fix the majority of problems that are likely to occur in your situation. There is an almost limitless list of possibilities for things that could go wrong, but the list is significantly narrowed by what will normally happen. For instance I'd say I can fix 90% or so of the problems that I encounter. I wouldn't say I know 90% of everthing there is to know about computers but in the scope of my employment I'd say I'm about 90% on.
I agree, given some research, I'll fix anything eventually. However, that wasn't my point. My point was, it's impossible to know 60 percent of EVERYTHING regarding to computers. If i'm given a job to do, i'll eventually be competent to do everything required of me 100 percent. And then...maybe it's time to move on to something else, unless the tasks are constantly changing and making me learn more and more.
You say you can fix 90 percent of the problems you encounter, well, that's probably 5-10 percent (tops) of all computer related things in the world.
yup, you shouldn't have to ask for help much, and if you designed the setup right (assuming you got to do the original design) you shouldn't have that much maintenance to do anyway.Originally posted by: Tiles2Tech
Originally posted by: spidey07
well....
Back in the old days we had to figure everything out ourselves. Want a driver for a printer? Well pick up the phone, call the company and get a floppy disk delivered.
Then came self service BBS to get said driver, log on, select model, download printer driver.
Then came the complexity of being ever connected, and more troubles.
Then came NOCmonkey's who didn't have to think and just simply looked stuff up on google.
well....
I do believe that was the sound of a glove being slapped across a face, duel-style. :Q
- M4H
