UberNeuman
Admit it, DVad3r - you're trying to get rid of a body.
Originally posted by: DVad3r
I'm not kidding either, this bitch is getting terminated, so either you guys assist me and get rep with a fat man from Canada, or I find other sources, which I'm pretty lazy to do 🙁
Originally posted by: Marlin1975
asphalt is not cement. Which one?
Amd for cement you would need a very strong acid. Easier to break it and then haul away.
Can't break it, too much noise. This must be done discretely. Honestly I'm not sure if it's cement or asphalt...sooo.
:evil: what are you destroying?
around 24 inches of 2 seperate speed bumps.
Who owns the pavement?
No chemical is easily going to destroy it.
Paving compaines use backhoes or jack hammers to remove such items.
Destroying public propery will generate you a bill for repairs and possibly a visit by PD
This is not something that you can do descretely in a couple of hours of weeks.
Originally posted by: ironwing
If asphalt, one of them there chipper bars (actual name escapes me at the moment) is your best bet. It may not seem like it but asphalt is fairly soft and breakable. Just chip away at it for awhile. If you don't want folks to be suspicious steal a couple traffic cones and buy a cheap hard hat and safety vest and work out in the open like you're supposed to be there. Anyone calls you on, shrug and say "They told me to take out this speed bump, so I'm taking out this speed bump."
Cement: a mixture of limestone, clay, and gypsum that has been heated to chemically transform the materials. Cement reacts with water, and after it dries, retains its strength even when re-exposed to water.
Concrete: Aggregate (sand/gravel/small stones) held together by cement
Asphalt: Aggregate held together by bitumin (material left over after the vacuum distillation of crude oil, aka "the bottom of the barrel")
Very strong acids may be able dissolve cements (and by extension, concrete). Dissolving asphalt will require dissolving the bitumin. A very strong solvent may work (ortho-xylene).
Originally posted by: Jeff7
1) Large old satellite dish
2) Lots of mirrors, or maybe a sheet of aluminized mylar.
3) Turn it into a giant reflector dish.
4) Wait for the proper angle of the sun, and direct a beam of searing heat at the speed bump.
5) Turn your new solar death ray on your neighbors.
6) Enjoy crispy Jones and Smith jerky.
Originally posted by: JMWarren
Doesn't gasoline dissolve asphalt?
Diesel screws it up when it's fresh asphalt.
Anything that will dissolve it will also fvck over the environment. Really shitty idea!
Riiiiight.
How dare he use petroleum based products on a petroleum based road surface!
Riiiiight.
Light oils and acids that will dissolve asphalt are a hell of a lot nastier than the road itself. It would make a nasty ass mess that the OP would not clean up.
Originally posted by: JEDIYoda
phaser or a photon torpedo!!
