There are voltage differences that could cause problems, but an i810 should support coppermines. I don't think it supports 133fsb though, so depending on the bus speed of your chip you may end up with a 750mhz p3.
It would be worth checking for BIOS updates before you swap in the new chip, but if you don't have a chip in the board right now, you will probably still be okay.
