Originally posted by: gregshin
thats pretty crazy...althought i was driving one handed and using the other hand to monitor my LCD readout which are displayed real time.
Originally posted by: Roger
You are going to blow the welds on your manifold using nitrous oxide.
HAHAHAHAHAHAHAHAHAHA
Originally posted by: AsianriceX
Depends on either your gearing, drag coefficient, or your tires. They can all limit your top speed. If your gearing is limiting, you'll hit redline on your last gear and that would be the limit. If your car is limited by drag, your engine can't provide enough force to overcome wind resistence. If your car is limited by your tires, the tires will probably blow up before you get to your top speed. They make different rated tires for different speeds.
Nice.Originally posted by: gregshin
1998 Nissan 240sx SR20DET
T-28 stock turbo 370cc stock injectors
Apex-i Power FC w/Commander
Apex-i Boost Controller
Greddy VSPL FMIC
Greddy PE2 exhaust
Blitz downpipe
Blitz DD BOV
Blitz dual timer
HKS Powerflo airfilter
Denso Toyota Supra fuel pump
SVR drycell battery
H & R track spring
KYB AGX short stroke adjustable shox
Pilot STB
Work Wheels Japan Maximer 18x8 18x9
235/40 265/35 Bridgestone Potenza S-03's Fronts and Yokohama AVS Sports Rears
300zx brake kit
If you do have a speed limiter, most of them can be shut off using a power programmer.
Originally posted by: Demon-Xanth
This chart will tell you the speeds of various gears given the right ratios. Fill in the yellow boxes with your car's info. http://mspencer.net/Demon-Xanth/calculations.xls
wow, that's cool as hell. I filled all that out and it said my car would redline at 149.31mph! :Q I dunno how accurate that is but at 5500rpm it said 114.06 which seems correct. awesome.
LeadMagnet: Is your car in a vacuum?
