Originally posted by: Wahsapa
Originally posted by: FallenHero
Originally posted by: Beau
Mac OS
Cute. Bubbly. Stupid. Easy.
works for me
me too :beer:
Originally posted by: Rastus
WinME -- Work on it all week long for a thirty minute ride on Saturday.
Originally posted by: Xionide
I will take xp. I can get what I want when I want reliably. I dont have to install a bunch of drivers in her to work (clothes, jewlry etc...). Plus if you play your cards right she looks pretty damn sexy.
-Xionide
Originally posted by: xcript
GNU/Linux
unzip; strip; touch; finger; mount; fsck; more; yes; fsck; fsck; fsck; umount; sleep;
Wife 1.0
Dear Tech Support,
Last year I upgraded from Girlfriend 7.0 to Wife 1.0 and noticed that the new
program began unexpected child processing that took up a lot of space and
valuable resources. No mention of this phenomenon was included in the product
brochure. In addition, Wife 1.0 installs itself into all other programs and
launches during system initialization, where it monitors all other system
activity.
Applications such as Poker Night 10.3, Boys' Night 2.5 and Sunday Football 5.0
no longer run, crashing the system whenever they are selected. I cannot seem to
keep Wife 1.0 in the background while attempting to run some of my other
favorite applications. I am thinking about going back to Girlfriend 7.0, but the
un-install does not work on this program. Can you help me, please?! Thanks, Joe
Dear Joe,
This is a very common problem men complain about but is mostly due to a primary
misconception.
Many people upgrade from Girlfriend 7.0 to Wife 1.0 with the idea that Wife 1.0
is merely a UTILITIES & ENTERTAINMENT program. Wife 1.0 is an OPERATING SYSTEM
and designed by its creator to run everything. It is unlikely you would be able
to purge Wife 1.0 and still convert back to Girlfriend 7.0. Hidden operating
files within your system would cause Girlfriend 7.0 to emulate Wife 1.0 so
nothing is gained. It is impossible to uninstall, delete, or purge the program
files from the system once installed.
You cannot go back to Girlfriend 7.0 because Wife 1.0 is not designed to do
this. Some have tried to install Girlfriend 8.0 or Wife 2.0 but end up with more
problems than the original system. Look in your manual under 'Warnings -
Alimony/Child Support.' I recommend you keep Wife 1.0 and just deal with the
situation.
Having Wife 1.0 installed myself, I might also suggest you read the entire
section regarding General Partnership Faults (GPFs). You must assume all
responsibility for faults and problems that might occur, regardless of their
cause.
The best course of action will be to enter the command C:APOLOGISE. In any
case, avoid excessive use of the ESC key because ultimately you will have to
give the APOLOGISE command before the operating system will return to normal.
The system will run smoothly as long as you take the blame for all the GPFs.
Wife 1.0 is a great program, but very high maintenance.
Consider buying additional software to improve the performance of Wife 1.0. I
recommend Flowers 2.1 and Chocolates 5.0. Do not, under any circumstances,
install Secretary With Short Skirt 3.3. This is not a supported application for
Wife 1.0 and is likely to cause irreversible damage to the operating system.
Best of Luck.
Tech Support
Originally posted by: Kibbo
Windows.
Nothing goes down more often.
