notposting
Urgh...mine is in town but delivery is on Monday. Can't wait to start toying with it when it gets here. Sounds like I will go with Froyo for the time being.
That is a common problem with the market cache. Go under settings, view all apps. Then clear the Google Framework data and Market cache. Then reboot. It should work then.
If you have a problem where certain apps don't show up in the market, install this:
http://code.google.com/p/market-enabler/
Using the Astro File Manager. Then run it and tell it to spoof a US T Mobile phone. then everything shows up.
same here, and i've got a real busy schedule come next week 🙁Urgh...mine is in town but delivery is on Monday. Can't wait to start toying with it when it gets here. Sounds like I will go with Froyo for the time being.
OK, how do I overclock this puppy? Is there a free app for it?
setcpu says it's $1.99, is there a free app too?
This. I'm interested in finding out what my Nook can actually take as far as OCing. Is there an app that simply displays CPU information and possibly testing that doesn't cost anything?
thanks, i'll check that out when my NC comes in :thumbsup:Many of you probably are beyond this point, but there's a nice post on the first steps in hacking the device here.
poofyhairguy, I really appreciate your posts, you encouraged me to install Froyo to eMMC, it made a huge difference.
Well I just tried to go to the Nook Froyo build and nothing happened I extracted the image, copied it to the card, put it in the nook and started it and nothing happened.
Download WinImage and use that.
I have that, when I direct WinImage to the folder I extracted the ROM to, theres nothing there! I just about bricked this thing a few minutes ago. I had to do a complete Re-root. Major panic there for a second. I dont' know what I'm doing wrong. I should wait till someone comes out with a super-easy install package for it. Yikes that was close.
