Originally posted by: Gamingphreek
Well they can monitor but what would we use to shoot them down. IIRC didn't one of the presidents look into lasers to shoot down oncoming targets. Is that possible.
Not currently, no.
did you read ANY of the others posts here...Originally posted by: Gamingphreek
-Kevin
Depends on what range you want to do it. the whole principle of a high altitude nuclear burst to take out a cloud of incoming ICBMs seems to do just as much harm as it does good, and with normal EMPs, you're looking at the same problems you'd face just launching a missle at it, as far as timing, burst pattern, etc. goes.Originally posted by: ribbon13
How powerful of an EMP would it take to disable an ICBM?
Originally posted by: f95toli
The problem with the shotgun method (and any other method) is the range, you would need thousands of them.
Not currently, no.
That is the airborne laser that was already mentioned in this thread, it is almost useless against an ICBM because the range is only about 300 km, you would need to have hundreds of the airborne at the same time to create an effective "shield".
The main problem is that lasers are not nearly as powerfull as most people think.
Maybe I'm the only sane person, but what terrorist would launch a nuke when they could fly to columbia and drive a boat w/ a nuke in it into the country, and then transport it via car. There goes your whole laser theory out the goddamn door. Have a nice day
Originally posted by: roguerower
Maybe I'm the only sane person, but what terrorist would launch a nuke when they could fly to columbia and drive a boat w/ a nuke in it into the country, and then transport it via car. There goes your whole laser theory out the goddamn door. Have a nice day![]()
Originally posted by: 302efi
You think you could Hi-jack a ICBM with a box-cutter ?:beer:
If a nuke were shot down with a something (Patriot Missile, Laser, ......rock ) it wouldn't blow up?
You guys said this is because it is very stable. When they arm the nuke what exactly happens?
I mean there is stil uranium or whatever in the Nuke even if it isn't armed so what is the difference.
Having kept up with the thread, i want to ask one question to make something clear.
If a nuke were shot down with a something (Patriot Missile, Laser, ......rock) it wouldn't blow up?
You guys said this is because it is very stable. When they arm the nuke what exactly happens? I mean there is stil uranium or whatever in the Nuke even if it isn't armed so what is the difference.
-Kevin
I might be wrong but as far as I remember the result of a "asymmetric" implosion (that some of the explosives go off before the others) is that the plutonium will "explode" because of some fission in the part closest to the explosives that locally causes extreme heating, however there will not be a chain-rection.
When they tested the first plutonium bomb they estimated that an assymetric implossion would cause an explosion which would roughly be as powerfull as if a similar amount of TNT had been used.
Hence, (as Gibsons has already mentioned) in this case you would likely end of with a lot of plutoniumdust+isotopes of various kinds from the fission but that should only be dangerous if you are close to the explosion.
