Pulsar
- Mar 3, 2003
- 5,224
- 306
- 126
It will be much more stable, and you shouldn't run into any cases of understeer, so it should track pretty much where you point it. It should help coming out of corners as well, letting you go full throttle a bit quicker.
I'm not sure, but they might be using narrower and a bit smaller tires than they otherwise would. The second set definitely seems to be smaller. I am surprised they didn't make them smaller still to help with the aero. If you look at the designs they had before, it seems they were going for that, so I don't know what the deal is.
Its probably pretty lightweight, it looks like a typical fiberglass bodied barebones car. It probably only added maybe 300-400lbs, which it could still be competitive in power to weight with plenty of cars if its 3500 lbs or so.
Actually, something like this would've made sense for something like the Veyron.
And exactly how do you figure it's not going to run into understeer? Contact area is only slightly related to friction - in fact "ideally" surface area isn't related to frictional force at all. I'll direct you to some of the most basic frictional formulas out there:
Friction Force = u (coefficient of friction determined by material and surface texture) * Normal force (weight).
This will have a minimal impact, if any, on friction in the front of the car. If you want to reduce understeer, change your weight distribution to affect your normal force, or break harder through the beginning of the turn to transfer more weight to the front tires.
