Idle 100 c for 2700x ?
eurgbp
27
is this a misreading or what?
https://drive.google.com/uc?id=1Z47C3gYeh-C4h5iznKcG4wcnBVL6tDLh
uc
Markfw
May 16, 2002
27,386
16,227
Thats 40c, not 100c. And thats not Ryzen master, so its probably off.
Markfw
May 16, 2002
27,386
16,227
why idle and die shows 100 c?
something is wrong with sensors?
I can't tell from that (small and blurry), and the other shots show 40c. Try Ryzen master, and screen print that and post here.
chrisjames61
721
446
I don't know why people even use these apps which are garbage imho because most people don't know how to interpret them. They see numbers they think are high and then they become alarmed. If your pc is built properly and running good without BSOD's, lock ups, frame stuttering, lags etc just don't worry about problems that aren't there.
eurgbp
27
disabled boost mode
now 3dmark passed ok
what is a max acceptable temperature for VRMs?
hdfxst
851
isn't a 2700x right at the limit of what that motherboard can handle wattage wise?
eurgbp
27
https://www.asrock.com/MB/AMD/A320M-HDV R3.0/index.asp#Specification
i am not chasing overclocking, i really don't care about it
i am not chasing GUCCI brands
if manufactures says 2700x is ok then I believe
CPU
- Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge, Raven Ridge and Pinnacle Ridge)
- 6 Power Phase design
- Supports CPU up to 105W
CPU Support List
Socket
Family Model Power Core Frequency Cache CPU Rev. Since BIOS AM4Ryzen 7PRO 2700X(YD27BXBAM88AF)95WPinnacle Ridge3.6GHz4MBB2AllAM4Ryzen 72700X(YD270XBGM88AF)105WPinnacle Ridge3.7GHz4MBB2AllAM4Ryzen 72700E(YD270EBHM88AF)45WPinnacle Ridge2.8GHz4MBB2AllAM4Ryzen 7PRO 2700(YD270BBBM88AF)65WPinnacle Ridge3.2GHz4MBB2AllAM4Ryzen 72700(YD2700BBM88AF)65WPinnacle Ridge3.2GHz4MBB2AllAM4Ryzen 7PRO 1700X(YD17XBBAM88AE)95WSummit Ridge3.4GHz4MBB1AllAM4Ryzen 71700X(YD170XBCM88AE)95WSummit Ridge3.4GHz4MBB1All
VirtualLarry
56,587
10,225
Yeah, bad system-integration choice, between that CPU and board, IMHO. Look for GamersNexus YT videos on best X470 mobos, Buildzoid narrates, and goes over the VRMs on each of those boards. Even some X470 boards, he doesn't recommend for a 2700X (!).
And you put one, on that "tiny" board? Good luck, you'll need it. Make sure to come back here in six months, for another mobo recommendation, after you burn out the VRMs on that board.
eurgbp
27
If I add heatsink to vrms I'd be golden
but
GIGABYTE B450M DS3H or ASUS Prime B450-Plus ?
I am here already =)
chrisjames61
721
446
look or is?
what else is needed for VRMs?
You need the right amount of phases and they must be quality and they must have at least passive cooling. To get all this you need to buy a quality board that is stout. Like somebody said Buildzoid has some good stuff on this.
escrow4
3,339
122
You are using a $300 CPU on a $60 mobo (with 2 RAM slots!) with what appears to be a sub $100 PSU? That is the equivalent of getting a $300 suit and matching it to some $20 shoes from Kmart . . . . . . build needs to be rebuilt before something sparks up and gives.
Indus
16,601
11,410
I have to agree, atleast get yourself a decent B450 motherboard if you can't afford a X470.
UsandThem
16,068
7,383
Nothing wrong with sub $100 PSUs, as there are many good options that can easily be had for less than that. Seasonic Focus Plus, EVGA G3, Corsair TX-M (and RMx), etc.
The real issue is the PSU they have. From what I can tell, it is a junk unit. On the manufacturer's product page, they state the SL-700 Plus is the:
The consequent development of the SL-700
While on the SL-700 product page, they state that it is:
The cheap power supply for price conscious customers
That doesn't inspire a lot of confidence to me, and makes me think that this PSU is on the same "quality" level as a Leadman or Deer.
Finally, I don't even know if they offer any kind of warranty as there isn't any details at all on this unit.
I see they offer a whole " 24 month guarantee". o_O
Reactions: Thunder 57
DrMrLordX
23,170
13,259
@eurgbp
At least you have the "plus" model that only has 150W on the 3.3V and 5V rails combined. The standard SL-700 has 28 amps on each rail. So bad. So bad.
That unit is probably good for the two years covered by the warranty. After that, I would say shut it down and replace it. It can probably handle your system as-is but it should not be treated as a "real" 700W PSU. It's closer to a 500W PSU. You don't want to put more than 300-400W load on it for any sustained period of time. If you want more, you need to get something like:
https://pcpartpicker.com/products/p...0000000000,700000000000&sort=price&e=4&page=1
EVGA and Seasonic aren't the only suitable resellers. Those are just examples. Personally I would look at the 650W Supernova G3. It's a good buy at that price.
As for your board, you need to tell us what size (ATX, mATX, etc) you require before we can recommend anything.
For the time being, you need to downclock and/or undervolt your CPU to reign in those VRM temperatures. It will also make life easier on your PSU.
Finally, what software are you using to monitor temperatures? Is that HWiNFO64? Have you updated recently? It should read temps perfectly off your CPU. You don't absolutely have to use Ryzen Master.
