identify usb wireless mouse adapter?
lm3
492
I have an USB wireless mouse adapter. Is there any way to determine what mouse it is compatible with?
Burpo
4,223
473
Is it RF or Bluetooth? There are no universal RF wireless mouse/keyboard receivers, and a given company's RF wireless/mouse keyboard receiver will not work with another's.
Most likely Logitech or Microsoft.. Does it have a one time "Connect" button?
http://www.microsoft.com/hardware/en-us/help/support/how-to/mouse/bluetooth
When you plug it in does a device show up in Device manager? If so you can find Vendor ID there..
mfenn
22,400
www.mfenn.com
:thumbsup: Right click on the device in the Device Manager and go to Properties -> Details -> Hardware Ids. The Vendor ID (VID) and Product ID (PID) will be listed there. Post those and we can try to dig up some info on it.
Burpo
4,223
473
That tells us nothing.. Put it in a PC and find it in Device Manager to ID the hardware.
lm3
492
Does not help. It shows up as a HID-compliant mouse with all the same info as other mice. They all show Manufacturer as Microsoft, even if it is a Logitech mouse and adapter.
mfenn
22,400
www.mfenn.com
Follow the instructions below, which will show you the raw ids from the hardware. What you're seeing as "Microsoft" is the provider of the generic driver. The hardware ids will tell us more about the specific USB device.
lm3
492
Hid\vid_05b8&pid_3166&rev_0034
hid\vid_05b8&pid_3166
hid_device_system_mouse
hid_device_up:0001_u:0002
hid_device
