Pariah, Fibre channel drives are not "repackaged SCSI drives with a fibre interface", rather fibre channel is a type of SCSI interface, much like Ultra 160 or Ultra wide, etc. However, you're 100% right that they have no place in people's homes. They're designed for servers which require very large numbers of drives, and / or long distances from the server itself. They are also capable of operating at a 200MB/sec interface, making fibre channel slightly faster than Ultra 160. The reason they're no good for home users is the $2000 price tag on a controller.
eyez, firewire drives are (from what I've seen) IDE drives connected via a firewire enclosure, like pariah said. The only advantage to them is portability, since firewire only runs at 400 Mbps (50 MB/sec, and ATA-100 is capable of 100 MB/sec), they're also generally significantly more expensive then their IDE counterparts.
JoshRtek, if you can afford SCSI, you will probably be very happy with it. Most 10k or 15k RPM SCSI drives are capable of matching, or coming close to matching IDE 2 or 3 drive RAID arrays in sustained transfer rate. In addition, they far exceed any IDE options in average seek time and average access time. Storage Review (
www.storagereview.com) believes average access time to be the most important statistic of any hard drive. I'm not sure how much of video editing is STR vs. access time, because I don't do video editing on my computer. However, the things I've read all suggest that SCSI drives are very useful in video editing, because "A/V optimized versions" of the drives are often available. A/V versions are the same drives with very large amounts of cache. For example, the Seagate Cheetah 73 A/V version has a 16 MB cache on it. (The non A/V version has 4 MB I believe). If you had an unlimited budget, I'd recommend SCSI RAID, but the controllers for that are often prohibitively expensive. In your case I think getting SCSI drives would probably be comparably priced to getting the IDE RAID configuration Pariah mentioned, because you won't need a $240 IDE RAID card, your 2940U2W is an 80 MB/sec Ultra 2-LVD card which can easily support two or three fast SCSI hard drives simultaneously ( so long as they're not X15s ). If you have multiple drives, SCSI brings in an additional advantage of being able to simultaneously access multiple devices, and allowing them to share the bus's bandwidth, whereas IDE is limited to a single drive at a time, taking turns to use the bus.
