Since I switched from WIN98SE to WIN2000, the IDE LED is always on solidly, no flashing except I turn off the computer. I didn't make any hardware change or even move a cable inside the case. Anyone knows what happened??
my friend's computer is running win2k with the same problem. don't know how to fix it. i changed all the cables and unpluged everything but still no help.
