ICS problem... I think its simple
Leros
Is it possible to have a setup like this?
cable modem ->
router ->
win xp -> (ICS)
Win 98SE
Can I have both a router and ICS?
Basically my router is across the house. I dont wanna spend money to buy a wire and then run i through the wall. I dont wanna spend any money actually.
The difference is running a 7ft crossover cable behind my desk vs crawling a 75ft cable through my attic.
I should buy a hub or a switch. But im trying to be cheap.
Hmm... So is using ICS and having a router impossible?
Apparently ICS needs the IP of 192.168.0.1 which is my router's IP.
