i7 D0 OC Causing Wireless Keyboard Connection Issues
Collider
522
7
So I had an issue w/ my MS Ergo 7000 keyboard which I posted about last week http://forums.anandtech.com/showthread.php?t=2231917
Was ready to buy a wired replacement, but then decided to reset my OC on the i7 rig in the sig. In fact the keyboard issue appeared around the same time that I did my overclock. After I went back to default settings keyboard started working as normal.
Now I know this doesn't make much sense and one thing shouldn't effect the other but this seems to be happening in my case. The OC was quite light, just to 3.2Ghz w/o any voltage modification.
This is really odd and never really seen anything like this, any idea what's causing this or how to resolve?
Puppies04
5,909
17
Just going to throw this out there as I have no idea if ti will help but have you installed the latest mobo bios?
Collider
522
7
Not latest but I've updated it sometime last year. But that wouldn't have any effect as the keyboard functions just fine w/o OC..
VirtualLarry
56,576
10,215
Perhaps one of the harmonic frequencies from the CPU clock, or the VRMs, is interfering with the radio frequency the dongle uses?
Collider
522
7
PCIE Freq => 100 ???
I think I may have it set on Auto, will double check once I get home. I wonder if it scales up on auto based on BLCK setting.
I was going for a very light OC so just have the BCLK @ 160 and v @ 1.100
