i7 CPU Not Flat
rip
613
50 - 55 IDLE!!!!
3 different heat sinks - not enough contact
anyone had this experience. I bought the chip from a private party, now I'm stuck
aigomorla
21,128
3,659
this is running stock?
rip
613
yes, all stock settings on an Asus P6T. The chip is concave. None of the three heatsinks even got close to the center with contact.
dguy6789
8,558
It happens sometimes. If you get a chip that is exceptionally nonflat, you should lap it or return it.
evolucion8
2,867
If he's brave enough, he could just remove the IHS and put another IHS from other CPU, I did that to my old system which had a Pentium M which comes with no IHS, and I used a old Williamette IHS and the temperatures dropped considerably.
Gillbot
28,830
17
check your TIM application. It's purpose is to fill the gap between the IHS and heatsink.
ZimZum
1,281
Don't lap it, just RMA it. If you want to lap a properly functioning chip, thats your business. But lapping an obviously defective chip to try and "fix" it, will in all likelihood do nothing but void your warranty and is a bad idea.
Originally posted by: SickBeast
OMG do NOT try to remove the IHS from an i7!
Also This
God Mode
2,903
AMD denied me when trying to exchange a 939 chip because they do not consider IHS flatness to be a defect.
rip
613
I'm waiting to hear from Intel at this point. If no go then lapping I guess. I'll try something besides AS5 first; something thicker to fill the gap. Should've left that thick stuff from Intel on the stock HS.
aigomorla
21,128
3,659
if u cant rma it, lap it.
But u can check for a warped ihs with a razor.
Put the sharp edge ontop of your IHS and see if any light bleeds though the gap if any.
If you have a large gap, it means your ihs is warped, if no gap, it means u have bigger problems then a warped IHS.
Diogenes2
2,151
Originally posted by: rip
I'm waiting to here from Intel at this point. If no go then lapping I guess. I'll try something besides AS5 first; something thicker to fill the gap. Should've left that thick stuff from Intel on the stock HS.
IC Diamond 7 Carat would be better for gap filling than AS ...
Zap
22,377
7
Shin Etsu MicroSI can fill the gap.
Gillbot
28,830
17
he should check his tim application and contact patch first. That will tell him how well his mount is.
dguy6789
8,558
Originally posted by: ZimZum
Originally posted by: evolucion8
I use that thermal paste and worked better for me than AS
A lot of stuff works better than AS
Link
There are reviews that show AS5 performing better than the Liquid Pro in that review. There is far, far too much widespread reviewer error to really be able to take away any kind of solid opinion on thermal pastes.
rip
613
UPDATE
Going to try another motherboard now. With the chip OUT of the socked it looks good (razor blade test), makes good contact. I believe the load plate is either bent or defective.
....more later
thanks all
edit: just an FYI; the motherboard was an 'openbox' item from Newegg. They are handling it well - return shipping label and all
Zap
22,377
7
Link
How it is applied can also affect performance. HardOCP had a roundup recently which showed differences from application methods.
People just think AS is the best because everyone else thinks it is the best. It is pretty darn good but so are a number of other compounds. Personally I don't use it because it doesn't clean up as easy.
aigomorla
21,128
3,659
UPDATE
....more later
thanks all
then you have other bigger problems. Like bad mount, or maybe your putting on too much paste. Or your internal sensors are messed up.
Guys stop fighting on filler TIM. His problem isnt a warped IHS.
ZimZum
1,281
Link
Another
And another
Seeing a trend here
And one for the road
