Axon
- Sep 25, 2003
- 2,541
- 1
- 76
This is the culprit: OCZ Gold DDR3 3x2GB 1600 (155x~ mhz) @ 1.66v. What are your timings? I would also reduce the RAM Mhz to 1333, or to any speed below 1600. While that kit is rated at 1600, it rarely can achieve that speed with any form of stability.
It drove me bonkers for three months while I figured it out - I had random restarts, rebooting loops whenever I restarted windows (while shutting down the PC for 90 seconds or more would ensure that it would boot just fine). I am not someone who is inclined to trash a particular piece of hardware, but there are so many stories of this RAM not running at its rated speed across the board.
http://www.newegg.com/Product/Produc...ords%29&Page=2
These are my settings for 3.6 on my ASROCK Extreme/OCZ Gold. 100% stable. Most will translate, but some will not, as I'm sure you already know. Give this a shot then bump for 3.8 accordingly (e.g., blck to 190, mess with QPI).
Overclock Mode
BCLK Frequency (MHz) [180]
PCIE Frequency (MHz) [100]
Boot Failure Guard [Enabled]
Spread Spectrum [Disabled]
CPU Ratio [20]
QPI Frequency [6.480GT]
Uncore Frequency [2880MHz]
DRAM Freqency [720MHz (DDR3 1440)] CRITICAL setting
▶DRAM Timing Control [8-8-8-24-88 (or auto)...auto for the rest, then CR-1T]
ASRock Vdrop Control [Without Vdrop]
CPU Voltage [Manual]
Voltage Value [1.21V]
DRAM Voltage [1.654V]
IOH Voltage [Auto]
VTT Voltage [1.340V]
ICH Voltage [Auto]
IOH CSI Voltage [Auto]
IOH/ICH PCIE Voltage [Auto]
CPU PLL Voltage [1.80V]
CPU Settings
CPU Ratio [20]
Enhanced Halt State [Disabled]
Intel Virutalization Tech[Disabled]
CPU Thermal Throttling [Disabled]
No-Exeute Memory Protection [Disabled]
Hyper Threading Technology [Disabled] (for now)
Active Processor Cores [ALL]
A20M [Disabled]
Overclock Mode
CPU Ratio [20]
IOH Voltage [Auto]
ICH Voltage [Auto]
CPU Settings
CPU Ratio [20]
A20M [Disabled]
