i7-6850k Easily degraded (My fourth replacement)
Headfoot
4,444
641
I think we can all agrees ASUS is the culprit here.
As for the comparison, my intuition says eDRAM has little bearing on the ability of the core to overclock. I concede I may very well be wrong, though I think it unlikely that the multiple BW-E CPUs I’ve had hands on have had the exact same results as in the article. The average for stability with Broadwell in general seems to be around 4.2 with anything above being above average.
Going above 4.2 results in huge increases in power consumption and voltage requirements regardless of ASIC quality and stability.
But that really isn’t the point of this topic, so I won’t continue to derail it.
Certain pieces of the core and eDRAM run on the same internal frequency bus so whichever fails first (its the eDRAM) limits the total overclock. That's why the Broadwell E chips can hit 4.4-4.5 and the eDRAM Broadwells cant.
Charlie22911
614
231
Golden samples can hit that with absurd power consumption and voltage, yes; odds of stability will be grossly against you however. If you want proof go lookup the binning results by Silicon Lottery, I won’t do the work for you.
Also eDRAM is not tied to core clock, It has its own ratio; the only other clock that affects its frequency domain is the bus clock. It can even be disabled entirely.
TLDR: Broadwell is a overclocking turd.
tential
7,348
642
121
He's counting the second one simply because it didn't overclock well...
That's kind of when I took it more as a joke than seriously.....
No one forced him to overvolt his CPU to get an overclock.
Edit: Guess I was wrong, looks like Asus may be to blame.
moonbogg
10,732
3,449
I've heard a lot of people claim their Asus X99 boards killed their Broadwell-E chips. Seriously.
Reactions: wilds
Dufus
675
119
101
I can't vouch for OP, but in my case it was two separate ASUS boards and two separate CPUs. This was for my first unRAID build so it was not overclocked, everything was set to stock to ensure stability. IIRC the ASUS board was setting my system agent voltage far higher than it should have been, causing degradation and eventual failure to boot reliably; even when set to stock it did this.
If your DRAM speed was left as standard and the board was increasing VSA then yes, that's an ASUS problem. On my Asrock X99 I also get high VSA if set on auto but only if DRAM speed is set higher than standard for HSW / BDW but then I have always been wary of auto settings and try to set them manually if able so VSA was a lot lower than Auto's offering. Now the OP seemed to indicate the fault was with core degradation and not IMC so to me that sounds like the core is getting too much current. Over voltage tends to be less subtle, killing a CPU in it's tracks. Not sure what that OC socket is doing but normally there would be some protection with FIVR fault protection enabled.
Back in the P67 days with ASUS they had a BIOS bug that would sometimes set the core offset voltage to somewhere around 0.8V IIRC when changing profiles. There was also a 1.5V max protection setting IIRC so perhaps if that was disabled, a positive offset originally used but a lower value in the profile, profile changed and the 1.5V protection overridden it may have had some consequences. At the time Asus reported they could not reproduced the fault even though one member posted how to make it happen. So one time even manual settings were not a guarantee.
Well stock turbo is 4ghz.
I thought the 6850k was 2 bins above the 6800k. For my 6800k the manufacturing turbo settings were 1-2 cores at 3.8GHz and 3 or more cores at 3.5GHz. That would make the 6850k all core 3.7GHz. My 6800k could only manage 4.0GHz stable with a little under 1.3V. More than 1.3V if I wanted to go higher. If I had known at the time I could get my money back from Intel I would have done it in a heart beat.
wilds
2,059
674
Does Broadwell-E also have eDRAM? I thought it was just a few Iris Quads. Oh nvm just DRAM*
LTC8K6
28,520
1,576
Well stock turbo is 4ghz. And it couldn't maintain 4.2ghz regardless of the voltage. It beats the purpose of a K series processor if I can't overclock it since I would keep it stock then. I decided to send it back and that was my decision. You're entitled to your opinion though. It was either that or I sell the processor and to get a different one.
4.0 is the single favored core 3.0 turbo number.
LTC8K6
28,520
1,576
Intel will generally take a chip back once without really pressing you on why you want to exchange it.
The warranty certainly does not cover "overclocks poorly". :D
I returned a 4790K and they didn't make me go through any hoops. Saying it didn't work was enough. The process was easy and I got a new boxed 4790K.
Dufus
675
119
101
Never had to RMA a CPU yet. In fact total RMA would be 3 mainboards. One was with Slot A that had problems out of the BOX but was so long ago I don't remember what they were and 2 other boards with B1 revision chipset SATA problem that was more of a recall really. One of those boards was swapped straight and the other one I had to pay extra because prices had increased! Seemed like something shonky going on with that one.
Carfax83
6,841
1,536
Strange. I've had two different Asus X99 boards, and I've never had a issue with degradation. My first board had a 5930K, and that overclocked easily to 4.4ghz on air and was able to maintain that speed as long as I owned it. It also easily handled DDR4 3200 speeds.
Then my current motherboard houses a 6900K, which I have at 4.2ghz with 1.267v, and DDR4 3400. Again, no issues with degradation whatsoever. That said, I know there has been some problems with X99 motherboards in general setting the system agent voltage WAY too high with XMP enabled. If you recall moonbogg, I caught that for you when you first upgraded to your current X99 setup :D Your system agent voltage was sky high, which definitely would have degraded your CPU if left unchecked.
But that issue obviously wasn't restricted to just Asus boards. A UEFI firmware upgrade fixed the problem. That's why it's so important to check for UEFI upgrades on a regular basis.
slashy16
151
59
The Intel RMA process is the best I have ever had to use. I had an Intel branded board that died once and it was replaced in three business days. It seems likely your board is faulty and killing the CPU's. I have deployed literally thousands of Intel CPU's over the past 9 years for the same company and I have never experienced a dead Intel CPU. I didn't even think Dead CPU's were a thing since they switched to LGA. I hope Intel is aware of the previous three dead CPU's or as the poster above me mention you are committing fraud.
moonbogg
10,732
3,449
Its true, you saved my life. You disarmed a landmine at my feet. This makes us brothers which means I'd do something nice for you, like buy you some special cat food or something. But the OP has another issue I think. According to many forum posts, a rash of people complaining over the course of a couple years have said their Asus boards were jamming a load of voltage in their CPU's and killing them. Clearly its not all Asus boards, and not even a large percentage of Asus boards, but maybe a higher percentage than usual when it comes to defects like this? There's a lot of noise about this online at Overclock.net and other sites.
I thought maybe instead of changing the CPU every 3 weeks the OP might put two and two together and try a different board for crying out loud. If my board fragged 3 CPU's, I'd totally not use that board anymore, regardless of brand anyway.
Carfax83
6,841
1,536
It's absolutely true that some Asus boards were dramatically increasing system agent voltage when XMP was enabled, but that was an X99 bug and wasn't confined to just Asus boards. A very high system agent voltage would definitely kill the CPU after a while, so it's possible that's what happened to the OP. However, this issue was eventually fixed with a UEFI update.
I agree. I've never heard of anyone having that many problems before. Generally, CPUs are hard to kill, and much sturdier than motherboards. I think I've only ever killed one CPU in my entire life, and that was back when I was just getting into computer hardware about 16 years ago.
Reactions: moonbogg
Ketchup
14,559
248
Hmm... A 10 % increase in core clock speed and you are on your 3rd CPU? Just stop. Don't overclock that one. Just enjoy it. Besides, you aren't looking at 10% increase all around. Things such as as bus, RAM, video card, SATA, eSATA, and USB speed aren't going to be changing from whatever they would be at with a base CPU speed.
Looking at it another way, the best over clocks I have every achieved were with a 2500k (3.7 GHz to 4.7 GHz) and an Intel Q6600 (2.4 to 3.8 Ghz) and unless I was compressing video, the difference was barely noticeable.
