Here is the problem. According to this test Haswell slowed down. SuperPi, Fritzchess, Cinebench 11.5 slower on Haswell. That's why I told the turbo might not work properly and you claimed all is fine with the turbo.
I'm telling you that Turbo works fine on 4770K since the increase from stock to 4.5Ghz
is reflected in the scores. I posted proof in post on 1st page, go back and read it.
The results are like that since 3770K obviously Turbos to near max. value due to board/bios/whatever. Super Pi uses legacy instructions so if it's slower there (by a
fraction of percent btw which is within margin of error) it's quite normal.
Here and
here you can see 3770K scoring slower than 4770K in this Chinese preview, a trend which I will demonstrate happens in other examples you used.
Another clue that 3770K runs at higher than normal Turbo (due to bios/board) is C11.5 score which is higher than normal as can be seen
here ,
here and
here. It should score 7.45-7.54pts on normal bios/board which is 7.88/7.54=1.045 or ~5% lower than what Chinese leak shows (again it Turbos to higher bin Vs the normal case). So taking normal score in C11.5 we can see Haswell scoring ~5% more, both at stock.
Last is Fritz chess. Under normal circumstances 3770K scores lower than what Chinese setup does :
here and
here . Normal score is therefore ~14000 pts or 4.5% lower than what Chinese review shows. Therefore Haswell is again showing higher stock performance vs normal 3770K.
Maybe they did run their 3770K under such a setup to make it more "even" since Haswell will be able ,at stock, to turbo higher and during longer periods of runtime Vs stock 3770K. This might be important for non-OCers but for enthusiasts that don't run stock setup it's basically unimportant.
