Hi guys,
I have been posting all over various OC forums trying to get some clear answers, as to how to properly decrease my overclock to 4.3GHZ or 4.2GHZ for my i7 3770K processor. I bought my system overclocked at 4.5GHZ, but the temps when under full load get too hot IMO...
system specs:
i7 3770k - overclocked to 4.5ghz
case: Cooler Master 942 HAF X
cpu cooling: 120mm Radiator Liquid CPU Cooler (CORSAIR H80)
motherboard: Asus Sabertooth Z77
idle temps: 30-40 degrees celsius
While running LinX, I reach 91 degrees celsius within 5 minutes with my current 4.5GHZ overclock (purchased and set by a major retailer).
screenshot: http://img23.imageshack.us/img23/2073/temps4.png
I have slowly been learning about overclocking... specifically on how to change the vCore and Core Ratio Limits to lower values (I don't understand the concept of PLL voltage/overvoltages).
However, I just noticed the seller of my computer also significantly changed my Digi+ Power Control Settings... making me now totally lost as to how to properly change my overclock to a lower value (4.3GHZ or 4.2GHZ ... whatever is easier).
Here are the screenshots of my Ai Tweaker and Digi+ Power Control BIOS settings (set by the seller):
http://img266.imageshack.us/slideshow/webplayer.php?id=94151800.jpg
Please help... just want to do this right and start using my new computer with confidence and that I didn't screw anything up or that it won't burn in flames while I'm not home. Thanks
system specs:
