- Dec 4, 2012
- 5
- 0
- 0
Hi im new to the forums and this is my first computer build from the ground up. Ie setting a cpu and cooler. I did try to enable tpu by flipping the switch on the mobo but in bios after it starts and shuts off a couple times it still only shows 3554 MHz nothing dramatic like 3.8-4 like i have seen ppl post on the internet.
P8z77 v pro
i7 3770k
Artic silver 5
Hyper 212+
Corsair 550d case stock fans no additional fans added. All doors on.
I spread a small line down the outer 2 grooves with thermal like most ppl recomemnded for the hyper212 coolers and a very small dot maybe a bb size in the center groove like some mentioned since the 212+ has more pipes and grooves then a 212.
Speccy
Cpu idle temps show ~40c
Cpu load temps show ~75-80c (running prime95 100% cpu)
Motherboard reads ~27c
Graphic card and hdds temps read 30-35c
CpuZ
Shows core speeds at 4100 MHz (just turbo boost?? Or mobo OC??)
Multiplier x41
Bus 100 MHz
Core voltage 1.144 V
Are these temps high?
Should i try and reset the cooler and thermal paste?
Any help appreciated thanks.
System at idle
After 5min or prime95. Core1 will usually get higher after about 15-20min to around 80c.
If you need more info just ask. Thanks.
P8z77 v pro
i7 3770k
Artic silver 5
Hyper 212+
Speccy
CpuZ
Multiplier x41
Bus 100 MHz
System at idle
